need help quick.
Old February 7th, 2012, 02:17 PM   #1
cleangtvert's Avatar
1991 gt vert
cleangtvert will become famous soon enough
need help quick.
i have a used walbro 190 but no pigtail. do i need it or can i just hook it up like the stock pump. the reason for urgancy is im about to order the sending unit (fuel level) from LMR. if it woint than i might need to order that also. doint want to pay shipping twice
Old February 7th, 2012, 02:20 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
How much is the pig tail ? If its not that much just order it any ways.... but to answer your question.....i dont know
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2012, 02:45 PM   #3
brandon444's Avatar
91 Mustang LX 5.0
brandon444 is on a distinguished road
I thought they switched over to free shipping?
Old February 7th, 2012, 03:03 PM   #4
1991 gt vert
ok ,guys thanks for the quick response. it looks like it does require a pigtail . i found it and orderd it for $5 bucks. also LRS did switrch to free shipping , or atleast on the fuel sending unit.
i've got more to add to this post, but i have to button up my driveway before the management says something. more later.
Old February 7th, 2012, 10:29 PM   #5
1991 gt vert
well its late so i'll keep it short tonite, but my guess was rite. the baffles in the tank broke loose and messed shit up!
Old February 7th, 2012, 10:53 PM   #6
I need a 5 lug kit
Ninety3Coupe's Avatar
1993 Mustang LX 5.0
Ninety3Coupe is on a distinguished road
Damn dude, that sucks. Is this common? I haven't heard of it. Pics?
Half of Maximum Motorsports Catalog, Full Intake, Full Exhaust. Needs paint and $35,000 in mods. Car / Build Photos: http://photobucket.com/CoupePictures
Old February 7th, 2012, 11:08 PM   #7
ryanw's Avatar
I must have missed your other thread....whats going on, was your car cutting out when the tank was low going around corners ?
255 fuel pump,
3:27 gears
Old February 8th, 2012, 08:27 AM   #8
1991 gt vert
^^^^yes. it has done it ever sense i got the car. the last time i posted about it was prolly a year ago or so.i got the car from an old freind that buy, and sells alot of cars and harlys. when he bought the car it wouldnt start. they replaced the fuel filter and pump. i live off a curvy road. it has a narlly S turn down the road. i would hit that turn and the car would cut out. so, i'd go to the station , but the car would only take about 6-7 gallons of fuel. the guage does not work either. i doint drive the car that much so i allways just filled it up whenever i drove it. i bought a zex wet kit that i have been scared to install until this problem is fixed. it would also cut out if the fuel was low on a hard luanch, and that would be a bad thing on the spray.i bought an extra fuel tank for $40 bucks abot 3 months ago because i had read about the baffles breaking loose. i decided to go ahead and drop the tank yesterday. first fucked up thing i see is the last guy cut the harness for the pump and sending unit and wired it back with fucking house wire nuts! i got the tank down . put it up un the tailgate of my truck to drain out the 12 gallons of fuel still in it. i didnt see any baffle in the tank! after i got most of the fuel out i tilted the tank a bit and their it was. it floated down from the other side along with the float, the float arm, and the sock !
also after closer inspection of the other tank i have. one side of the baffle in it had allready broke loose wtf! i took a stick to push the baffle down and ran a couple of sheet metal screws through the bottom of the tank into the tab on the baffle that should be tack welded inside. sanded the area down and jb welded the shit out of it! i got a mew fuel sending unit coming from LMR, and the pigtail for the walbro coming from APC. both are in texas so it will be abot three days. i also had o'rileys order in some electrical conectors. i'll be getting them this morning to fix the wireing with something other than fucking wire nuts!!!
Old February 8th, 2012, 11:14 AM   #9
ryanw's Avatar
Oh wow, that sucks bro.
I didnt know you could weld a gas tank that has already had fuel in it...... i remember high school auto shop, and the teacher saying never to do that...lol
255 fuel pump,
3:27 gears
Old February 8th, 2012, 03:01 PM   #10
1991 gt vert
J B WELD
Old February 8th, 2012, 08:17 PM   #11
I need a 5 lug kit
1993 Mustang LX 5.0
That's unbelievable dude. Wire nuts? I wish you could find that guy and kick him in the balls and thank him for nearly killing you. That is a little tiny short away from an explosion. What a dick!
On the upside, congrats for finding the problem. It may suck, but at least you know wtf is wrong!
Good luck and keep us posted! Pics please as well.
Old February 9th, 2012, 08:24 AM   #12
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Wire nuts...... WOW. Hell, as an electrician, I would never do that! Although, my Abaco maf pigtail is wire nut'd right now cuz I just wanted to try it out! I'll solder it before it gets any road use though, lol. Vibration and wire nuts sometimes aren't a good mix, hahahhahaha.
Old February 10th, 2012, 07:35 AM   #13
1991 gt vert
ill get some pics up today guys. i started a big roof job yesterday and was to damn tired to mess with the cumputer last night. got the tank all ready to go cleaned it out with some acetone to get the little bit of varnish out and then took it to the car wash and souped and rinsed it out. i'll be happy as hell to have a fuel guage again.
Old February 10th, 2012, 10:00 PM   #14
1991 gt vert
ok, so here are some pics first one the filler neck
now for the wire nuts!!
now here is what you should see when you look into the tank (doint mind the orange liquid, its acetone eating the little bit of varnish that was in the tank)
and this is what you doint want to see
had to get two sets of electrical conectors and some butt conectors to fix the harness
needed two of those. i'm still waiting on the pigtail for the walbro to get here.
Old February 12th, 2012, 01:36 PM   #15
1991 gt vert
more f--king problems! the walbro woint fit in the hanger! insted of a flat washer-like bottom of the hanger its more like a cup at the bottom for the pump to sit in. it's about 3/4 inch deep and the walbro is a ****-hair fatter. cut ,chop, reweld time! lol! screw spending another 90 bucks! i took a screwdriver and beet the welds off. i'm going to cut it down to the thickness of the rubber isolator and weld that bich back on! this shit is starting to really piss me off, but atleast i think i can re-engineer this prick. i'll try to take some pics latter my i-phone is in the middle of a re-boot right now and i have a b day party for an employe's daughter to go to in a bit.
Threads Similar to: need help quick.
Quick! Quick! About to pull the trigger on some 3.73s... Iconoclast107 2005 - 2010 10 November 29th, 2010 12:47 PM
quick quick i need a drinking game for 3 people BostonPerformance The Clubhouse 21 April 22nd, 2010 12:15 PM
Meguiars Quick deatailer.. or Ultimate Quick detailer?? svtkidd23 General Car Care & Detailing 12 January 26th, 2009 12:23 AM
Quick question...need very quick answer-please ZOOTOXIN 2005 - 2010 11 December 9th, 2008 10:20 PM
alright quick quick light tint question thorpedo26 The Clubhouse 18 September 1st, 2008 07:36 PM
