Floorpan install
Old February 7th, 2012, 04:04 PM   #1
1989 Mustang GT
All day
sclass-hole has a spectacular aura aboutsclass-hole has a spectacular aura about
Floorpan install
Advice?
Suggestions?
Top or bottom?
Weld or glue?
I think it definitely needs replaced.
Old February 7th, 2012, 06:02 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
Ive never done this, but i agree it should be replaced. And im willing to guess that since are cars are unibody that the floor pan should be welded just for sheer strength and ragidity
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2012, 09:45 PM   #3
FastStang91Lx's Avatar
1991 Mustang LX 5.0
Cut out and replace!
Threads Similar to: Floorpan install
Floorpan Thickness 79-93?? Nuclear 5.0 Mustangs 2 October 5th, 2010 12:24 PM
help on floorpan/rust fixing. mmikeclass06 Classic Mustangs 6 April 22nd, 2009 11:52 AM
replacing The Floorpan marks87gt General Tech 3 October 22nd, 2007 08:19 PM
Storm Drains Blocked (Puddle in backseat floorpan) ToplessSteed General Tech 6 July 12th, 2007 05:28 PM
Any Tips To Welding In A New Floorpan? REBELPONY 5.0 Mustangs 23 September 19th, 2006 06:04 PM
