New to mustangs and lookin for info, thanks
Old February 7th, 2012, 04:41 PM   #1
1992 hatch back
murdock.dean is on a distinguished road
tryin to set up a 10 sec car
I just picked a 92 mustang with a 460 big block in it. The guy told me it was bored 30, with a cam but he lost the card so couldnt remember the specs. It does have a good lope to it tho. Also has an intake, holly 750 double pumper and all MSD ignition. It does have a nitrous plate kit on it but miss alot of part to be finished. Im lookin at changing the push rods, rockers and springs and gettin the parts for the nitrous to be hooked up. Was wondering if a 150 shot would be able to put the car into the mid to low 10's in the 1/4. any info on the setup to make this happen would be appreciated thanks.
Old February 7th, 2012, 05:41 PM   #2
ryanw's Avatar
1991 Ford Mustang GT
If you dont know what cams in it, how are you going to get the right springs, do you plan on measuring the cam or pull it out to see the s/n ? Also why are you going to replace the push rods ?
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old February 7th, 2012, 05:47 PM   #3
1992 Mustang LX
13.0 @ 105
StangBanger302 will become famous soon enough
We would have to know the cam specs, cylinder head info, what intake, weight and gear/Tranny info to tell you honestly.
As I lay rubber down the street
I pray for traction I can keep
But if I spin, and begin to slide
Please dear God, protect my ride
Old February 7th, 2012, 08:50 PM   #4
gripthenboost's Avatar
91 Mustang GT
1991 sliver GT
gripthenboost will become famous soon enough
More info or pics would help alot. Also welcome
Old February 9th, 2012, 01:10 PM   #5
1992 hatch back
I just got the car dont know the weight but i would say not much less than stock curb cause of the BB. it has a built c6 trans, 3.73 rear gears. all the guy could remember on the cam was 580 lift. stock heads with mild work. changin the rods, spring and rockers cause they are just stock ones in it.
Old February 10th, 2012, 01:31 AM   #6
crazy old cuban's Avatar
1990 mustang gt
crazy old cuban is on a distinguished road
Smile
nice stang and welcome
never to old to run
Old February 10th, 2012, 11:54 AM   #7
1992 hatch back
Thanks man
Old February 11th, 2012, 04:42 PM   #8
1992 hatch back
any insight on what to change or add to the build would be helpful, thanks guy
Old February 12th, 2012, 03:05 PM   #9
1992 hatch back
just seein if anyone has some advice to help me get my setup into the 10's
Threads Similar to: New to mustangs and lookin for info, thanks
New to mustangs need info Texastruckguy 5.0 Mustangs 1 September 4th, 2011 11:12 AM
New to MM and Mustangs- need some info? codyjhall91 99-04 10 February 19th, 2011 12:00 AM
mustangs and fast fords mag...info yeah_itsa_v6 The Clubhouse 6 May 4th, 2010 05:48 PM
The Official 99-04 Info & How-To Center ***DIRECT LINKS TO INFO*** 06RedfireGT 99-04 7 April 5th, 2010 01:53 AM
lookin for some info from any of you 5.4 or 5.4 swap guys 1TITAN Modular Mustangs 3 June 18th, 2009 08:09 PM
