89 GT
Torque spec ?
Anybody have a link to a site where I can get all the torque specs for all the bolts in my motor?
5.0L Torque Specs
Belhousing to engine bolts 28-38 ft/lbs Camshaft sprocket bolt 40-45 ft/lbs Camshaft thrust plate to engine block bolts 108-144 in/lbs Crankshaft pulley to vibration damper bolts 35-50 ft/lbs Cylinder head bolts -1979-1992 --Step 1 55-65 ft/lbs --Step 2 65-72 ft/lbs -1993-up --Step 1 25-35 ft/lbs --Step 2 45-55 ft/lbs --Step 3 75-85 ft/lbs Differential shaft lock bolt 15-30 ft/lbs Driveshaft U-joint to pinion flange bolts 70-95 ft/lbs Exhaust manifold bolts 26-32 ft/lbs Flywheel mounting bolts 75-85 ft/lbs Front engine mount nuts 72-98 ft/lbs Intake manifold to head bolts --Step 1 96 in/lbs --Step 2 16ft/lbs --Step 3 23-25 ft/lbs Intake manifold (upper intake to lower) 12-18 ft/lbs Oil filter insert to engine block adapter bolt 20-30 ft/lbs Oil pan mounting bolts -1979 --Step 1 (Large bolts) 11-13 ft/lbs --Step 1 (Short bolts) 7-9 ft/lbs --Step 2 (Large Bolts) 15-17 ft/lbs --Step 2 (Short Bolts) 10-12 ft/lbs -1980 to 1987 9-11 ft/lbs -1988 to 1993 6-9 ft/lbs -1994-up 110-144 in/lbs Oil pickup tube to main bearing cap nut 22-32 ft/lbs Oil pickup tube to oil pump bolts -1979 to 1987 10-15 ft/lbs -1988-up 12-18 ft/lbs Oil pump mounting bolts 22-32 ft/lbs Pinion bearing preload 8-14 in/lbs Pressure plate to flywheel bolts 12-24 ft/lbs Rocker arm fulcrm bolts 18-25 ft/lbs Spark plugs 7-14 ft/lbs Timing chain cover bolts 12-18 ft/lbs Vibration damper to crackshaft bolt 110-130 ft/lbs Wheel lug nuts 85-105 ft/lbs enjoy
please..it's an ENGINE................*L*
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
89 GT
Wow, I hope you copied and pasted!
Haha, thanks. |
Threads Similar to: Torque spec ?
| v6 spec ? | Danderson | V6 Mustangs | 2 | April 15th, 2007 12:51 AM |
| Lug Nut Torque Spec? | Timber | 99-04 | 31 | April 14th, 2007 12:25 AM |
| sixer vs. spec v | 94pacecarSVT | V6 Mustangs | 9 | February 1st, 2007 08:51 PM |
| Spec Clutch | 00SoSlow | V6 Mustangs | 3 | June 28th, 2006 03:31 AM |
| Spec Clutches | 4point6GT | 96-98 | 6 | June 27th, 2006 07:49 PM |
