1993 Mustang GT
Mass air flow sensor torx removal but?
Where can I get a torx bit that will remove my mass air flow sensor?i have torx buts but it looks as if ford made a factory unique tool for removing this.those bastards.
Sent from my Autoguide iPhone app
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong. BBK CAI Dual Flowmasters Hurst Shortshifter Smog Delete Gatorback pulleys. FULL LED Tailights NEWEST ADDITION: Eaton M90 supercharger kit |
1991 Ford Mustang GT
Why do you want to remove it ?
I think if you take a torx screw driver and drill a hole in the middle of it, it should work, but again i dont know why you would want to remove it
1993 Mustang GT
To clean the wires in it,and the sensor.
That not how you clean it.
You need maff cleaner, you spray it in side of the housing. Theres a senser that inside, and you just spray it out a few times, and let it dry
This what your trying to clean, the inside of your maff may look a little different, i just pulled a picture from some random site.
![]() Use maff cleaner not carb cleaner, and dont touch the sensor with any thing, there fragile
1991 Mustang LX 5.0
It's a security torx bit.
Point made in less than a few hours with minimal response. http://www.moddedmustangs.com/forums...ml#post4465184 |
I removed mine to clean it, you don't have to but it you have full access to it. I have some cheap 100 piece security bit set from Harbor Freight for like $7 years ago. Enough different types of bits to work on most "security" screws
http://www.harborfreight.com/100-pie...set-91310.html
1991 Mustang LX 5.0
Damn, that's cheap. I was in a pinch when I needed one and bought my set from NAPA. Wasn't so cheap! I wish there was a harbor freight near me.
![]() Join Date: Jun 2011
They are called tamper proof torx bits. Sears sells them. Even Harbor Freight may have them as nolife said.
1988 lx
9.68@142
the bits are sold most everywhere. ive even seen them in the $5 tool bin at big lots.. they are uausally just a bit not a whole screwdriver
1993 Mustang LX
I got my security hole torx set for $7 at Lowes btw they're nice to have. The ignition siwtch is also a security hole torx as well so its not a bad idea to pick a set up.
We sell a gear wrench set at advance auto, but it's like 30 bucks....lifetime replacement though! Haga
Sent from my Autoguide iPhone app |
Threads Similar to: Mass air flow sensor torx removal but?
| mass air flow sensor | BAD98GT | 96-98 | 4 | December 6th, 2010 06:04 AM |
| Mass Air FLow sensor | Maverick530 | 99-04 | 5 | December 3rd, 2010 05:37 PM |
| Mass Air fLOW sENSOR | Robert10 | 5.0 Mustangs | 1 | October 31st, 2010 01:58 PM |
| Mass air flow sensor | Paulnhbtx | 99-04 | 3 | December 31st, 2007 09:13 PM |
