Stang wont stay running, after warm up...????
Old June 14th, 2006, 11:35 PM   #1
ttop5.0's Avatar
ttop5.0 is on a distinguished road
Could it be the fact that maybe there is no wire coming off of the alternator to the ground??? the Local "auto parts superstore" says that i don't need to have a ground wire hooked up to the alternator, i have the old style ford alt. pn 7078 with separate field power and stator hook ups??????
Old June 15th, 2006, 10:13 AM   #2
ckthecerealkiller is on a distinguished road
You definately need a ground but that might not be the problem.... Just try that and see if it is something else....
Also, if you just let your car sit in the driveway and idle for about 15 minutes and then it dies it could be a number of problems.
Ground the alt, check the fuel filter and all of your other fluids, make sure that your intake isn't clogged up, (might want to oil it if your intake calls for it once a year), check all of your spark plugs cause it could be a misfire......
It could be a number of things.........
Old November 28th, 2006, 04:10 PM   #3
stang94 is on a distinguished road
get a stick and beat the mustang.. it will keep running when its hot...
lol j/k bored at work here.
Giving Away For FREE PM ME.
FREE 351 Block, 90,xxx miles (Non roller block)
FREE 94-98 GT Hood (red)
Threads Similar to: Stang wont stay running, after warm up...????
88 5.0 sometimes starts but won't stay running cylance 5.0 Mustangs 8 August 28th, 2011 05:59 PM
Got Her Running, But wont stay running...help? Speedstang302 5.0 Mustangs 10 August 28th, 2011 05:58 PM
wont stay charged itsmyfiveoh 5.0 Mustangs 1 June 22nd, 2007 03:26 AM
Wont Hold Idle When Warm zero 5.0 Mustangs 22 March 16th, 2007 11:39 PM
1988 5.0 wont start when warm and sits for a few minutes hoserc1 5.0 Mustangs 17 February 26th, 2007 04:08 PM
