1989 GT Hatch
how do you depressurize the fuel system?
i'm going to replace my fuel pump, fuel filter, add a adjustable fuel pressure regulator with gauge. any tips on the jobs ahead? |
should be a button in your hatch behind the interior piece, right by the where the striker comes down...At least that is where mine is...Hit the button and then turn on the key, if you dont hear the fuel pump turn on, then go for it.
1989 GT Hatch
where?
OK, all that button does is cut power to your fuel pump. Which is also achieved by not putting you key in the ignition and turning it, so really there is no reason to do that.
You fuel system only stays under pressure for about 5-10 minutes after the car has been running. The regulator slowly bleeds pressure and after a few minutes with the car off and the ignition in the off position there shouldn't be any fuel pressure. If you are really concerned (its only 39 PSI) you can get a pressure checker to make sure there is no pressure.
88 GT CHI headed 351w 10.8 @ 125 - still figuring it out. 03 Cobra 2.3 whipple 10.7 @ 129 - sold it 04 Mach 1 12.7 @ 109 mostly stock - sold it 89 LX procharged 302 515 hp 497 ftlbs 10.7 @130 mph - sold it
theres a collision-actuated sensor in the fuel system that will shut off power to the fuel pump. in most sedans and verts its in the trunk on the left hinge support and for the hatch its in the trunk on the left taillight panel...you can pretty much bang on it to deactivate it or you can take off the plastic panel to get to it....
its called an inertia switch. up is open, down is closed. you want open. dont just wait for it to bleed down. thats rediculous, you dont want to take ristks with fuel and your health. open your hatch and remove the paneling immediately behind your drivers sie tailight. you can take a flathead and gently pry up on the little red button. after it is up, start the car and let it run untill the car dies. your fuel system is now depressurized.
92 lx 351W w/ 60 overbore holley 600cfm carb weiand stealth dual plane intake 240/246@.510 cam bbk long tube headders msd coil 5 lug axle conversion 3.55 gears mach1 style 17" rims |
#7 | |
To depressurize the fuel system is to locate the inertia switch which is behind the interior piece on the driver side back. Start ur car then un plug ur switch then ur car will run for a couple of seconds to get the fuel pressure out of the system then when it cuts off ur system has been depressurized. The u can work on the fuel system, there still might be some fuel still in the system especially in the fuel filter. But when u got the fuel system done the u hook the switch up press the button on the top of the switch and turn your key onf 4 or 5 times to build the pressure and fuel back up.
1989 GT Hatch
thanks everyone.
#10 | ||
^^ haha well, someones thinking.
OK here is a thought if you still have the stock fuel rails why dont you just put a rag over the schrader valve in the engine bay and slowly push it in with a small screwdriver and be done with it..
Yeah I was wandering why nobody had suggested that.
#15 | |||
I think my garage floor will be OK with an once of gas on it... jeese, do you need a skirt too... |
^^because people like me who work on jets for a living and are around hazardous materials like hydraulic fluid, engine oil, and gasoline products know its not really anything to mess with too often. sure ill wear a skirt, but when your kids come out with a few extra chromosomes.. dont say i didnt warn you. whats so pussy about erring on the side of caution anyways?
Bringing disabled children into this is hardly called for...
Nothing wrong with being cautious, but saying something isn't safe without any reasoning seems pretty "mom" to me. Trust me, a return style fuel system has no fuel pressure 5 minutes after its been running. Furthermore, even if it had 100 PSI fuel pressure, that would not result in any more fuel exposure since the pump is still off, only an ounce or so of gas would be spilled and the pressure would drop to zero instantly (b/c liquids do not compress much). There is nothing dangerous about it, most shops do it this way because a lot of cars do not have an inertia switch and some are impossible to get to or have a tendency to get stuck in the off position. Next you'll be saying it's bad to wash your hands in parts cleaner...lol PS all my children have the normal number of chromosomes...46...I dated a girl with three nipples once though...
#18 | ||||
I would tell your girlfriend to wear skirts more often, but half the time her clothes are thrown on the floor anyway so it wouldnt matter.
48.47@ 12.58
resorting to name calling huh...
how fun
Who is name calling?
Threads Similar to: how do you depressurize the fuel system?
| Fuel System Help! - 89 LX | Super Stock | 5.0 Mustangs | 30 | October 21st, 2007 11:54 AM |
| Fuel System Upgrade??? | 95blackbeauty | 94-95 | 1 | September 5th, 2007 03:31 PM |
| fuel system | Iownastang | 5.0 Mustangs | 1 | July 2nd, 2007 01:29 AM |
| fuel system | mmvi | V6 Mustangs | 22 | June 3rd, 2007 01:00 PM |
| What's diff about 98 GT fuel system? | markush | Modular Mustangs | 3 | February 6th, 2007 02:25 PM |
