I'd suggest following the recommendations by the manufacturer.
If there are none, then between 2-12" from the transmission side u joint. Pick a spot where you get the most clearance and remember that your axle moves up and down and in an out a little bit with the rear end. |
Thanks.
I have the Summit house brand and I lost the instructions. Several other models they sell call for roughly 4-6 in. I'll see if I can find a compatible spot in that range.
NHRA requires the loop to be within 6-inches of the front u-joint.
1990 LX hatch
mount it between your jaw and your shoulders and bolt it to your seat.
#6 | |
#7 | ||
laekwood ones are really good
#9 | |
13.64@101mph
1990 GT- 5.0L |BBK Shortys|VRS O/R X| SLP LM1 Catback|BBK CAI| Centerforce Clutch|MGW Short Throw| Alum D/S| 3.73's| Steeda Springs...about as stock as a 5.0 comes now a days..much more to come |
Threads Similar to: Drive shaft safety loop location
| drive shaft shop one piece steel shaft ok for automatic tran | mustang fanatic | 2005 - 2010 | 8 | September 24th, 2007 02:21 AM |
| Hurst Short Throw and BMR Front Drive Shaft Safety Loop | Gunny | 2005 - 2010 | 2 | August 20th, 2007 12:26 PM |
| Drive shaft loop | GreenFaleen | V6 Mustangs | 2 | May 4th, 2007 07:48 PM |
| drive shaft ? | Drgnracin72 | 99-04 | 2 | April 13th, 2007 11:26 PM |
