1993 Mustang LX Vert
Trick Flow street and track heat
How can I tell the difference between the two? The reason I ask I because I have one or the other and now found out that with the Track heat you cannot have an EGR and my car has it. Can the EGR system be done away with to make the Track heat work and how difficult would it be? Thanks for your help.
unless you have some surrounding mods that work in that intakes rpm range I wouldn't use it
EVERYONE IS ENTITLED TO MY OPINION:cool: 6'ers are for kids 1965 chevelle SS 421 sbc 6 speed, 3.90 gears,alum d-shaft, brodix heads,roller cam,925 AED carb...grocery getter*[COLOR="Red"]RIP[/COLOR]* |
Street has 15" runners and Heat has 12" runners. Street is idle to 5500 and Heat is like 1500 to 6500 rpm range. If you don't need a inspection sticker, you can do away with the egr, but like said before, I would stick to the Street model unless I was going to upgrade my heads and cam also to the same working range. Both are 75 mm inlets.
My plans are to add a set of Trick flow heads along with a stage 1 or 2 cam and new roller rockers, pistons, rings, push rods, roller lifters, etc. I was just wondering if I can easily do away with the EGR spacer and components to use the track heat set up.
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer |
Threads Similar to: Trick Flow street and track heat
| Trick Flow Track heat valve springs? | Tony_90fox | 5.0 Mustangs | 2 | June 23rd, 2007 02:31 PM |
| Trick Flow Track Heat Top End Kit | shurb125 | 5.0 Mustangs | 4 | April 20th, 2007 12:31 AM |
| Trick Flow Track Heat Kit | Erron89 | 5.0 Mustangs | 6 | February 8th, 2007 06:08 PM |
| Trick Flow Street Heat | stang94 | 5.0 Mustangs | 25 | December 11th, 2006 12:34 PM |
