HP and Quarter Mile Guess - Forums at Modded Mustangs
post #1 of 27 Old February 24th, 2012, 01:16 AM Thread Starter
Just curious what kind of HP i'm pushing and what i should be doing on a quarter mile. It's a pretty basic build.
Ported GT40 Heads
T-Moss Ported GT40 lower intake with Upper Tubular intake
1 inch phenolic spacer
1.7 Roller Rocker
Stock Cam (i know, biggest choke)
70mm Accufab
70mm Pro-M MAF
Moroso Cold Air Intake
Underdrive Pullies
AC Delete
Eibach Drag Springs
Lakewood Shocks 70/30 fronts, 50/50 rears
BBK Rear Upper and Lower Control arms with Polyurethane bushings
4.10 Gears
subframe connectors
AOD with Transgo Shiftkit and 3k Stall
180 T-stat
bbk shorty headers no Cats with Magnaflow mufflers
Draglite rims on street tires
much appreciated, thanks
bennyjet846 is offline
post #2 of 27 Old February 24th, 2012, 02:40 AM
StangBanger302's Avatar
On street tires? Just put slicks on for the track. I say a 13.0 on street tires and a 12.4/5 on slicks. Stock cam is a decent cam...Id rather have that than the shitty b I have now.
N/A or N2O Iron headed SBF coming summer 2015....Long ass build
StangBanger302 is offline
post #3 of 27 Old February 24th, 2012, 03:16 AM Thread Starter
i'm planning to get drag radials after the paint.
post #4 of 27 Old February 24th, 2012, 03:57 AM
johnGT's Avatar
That's probably around 260rwhp. 13's does sound about right.
1995 Mustang GT vert: AODE, 2.73 gears, O/R xpipe flowtech mufflers , 410,000~ miles.
2007 Mustang GT: 4.6, 5-speed, 3.55 gears, black on black. (dads car)
johnGT is offline
post #5 of 27 Old February 24th, 2012, 09:42 AM
coreyflipp's Avatar
You might be suprised with what that combo will do. People have gotten some pretty fast times with that setup. And like said before, the stock cam isn't that bad. On a mild setup like that it's probably about the best choice as far as having a smooth powerband while still performing decent.
2002 gt 5-speed slow
1990 gt 5-speed junk
coreyflipp is offline
post #6 of 27 Old February 25th, 2012, 03:01 AM Thread Starter
260whp? lol i hope so. i was guessing that i was probably around the 240rwhp range.
post #7 of 27 Old February 25th, 2012, 08:39 AM
Ohsplat's Avatar
Send a message via Yahoo to Ohsplat
The 1.7 rockers will add lift without changing the duration as far as I know. The lower duration of the stock cam gives you that nice torque muscle cars need for a nice launch. The only can I would use over stock is a custom ground, and with your set up that probably wont change much from stock.
Ohsplat is offline
post #8 of 27 Old February 25th, 2012, 08:41 AM
Ohsplat's Avatar
I was thinking 240-260 Hp at the flywheel and 15 to 20% loss thru driveline.
Ohsplat is offline
post #9 of 27 Old February 25th, 2012, 09:17 AM
02sonicGT's Avatar
not sure if this website will have accurate/updated data for the 5.0's but you can do a search and see what you come up with
Drag Racing 1/4 Mile times 0-60 Dyno Fast Cars Muscle Cars - DragTimes.com
And then althought not 100% accurate you can take the ET and weight to estimate HP
ET-MPH-HP Calculator
SOLD : 2002 Sonic Blue GT - Vortech V3-Si, Treadstone TRV25O, Tial Q, PMAS HPX MAF
2014 Ruby Red F150 Ecoboost - Bone stock....For now.
Click Here to see my Vortech V3 Build Thread
02sonicGT is offline
post #10 of 27 Old February 25th, 2012, 12:49 PM
9-secgt's Avatar
iron gt 40 or ford racing gt-40 y or x heads....
9-secgt is offline
post #11 of 27 Old February 25th, 2012, 12:54 PM
gripthenboost's Avatar
Thats a good street build
gripthenboost is offline
post #12 of 27 Old February 25th, 2012, 03:39 PM
9sec.gt- Hes using the iron GT40 heads.
post #13 of 27 Old February 25th, 2012, 03:40 PM
It would change a decent amount from stock, actually. Definitely more lift...Something in the. 510-.540 range and a little more duration to make it pull higher.
post #14 of 27 Old February 25th, 2012, 04:57 PM Thread Starter
yup, iron heads. that calculator is pretty cool. if i were at 260rwhp, it calculates me running at 13.1
i'll know for sure in a month from now though, i'm going to dyno it to see what i'm really producing. thanks guys
post #15 of 27 Old February 26th, 2012, 01:04 AM
You're probably right around 250-265rwhp with the stock cam. Swap it out for a custom grind and you can be near the 300 mark.
post #16 of 27 Old February 26th, 2012, 04:55 AM Thread Starter
i may do that after the summer. another project to look into.
post #17 of 27 Old February 26th, 2012, 06:43 AM Thread Starter
is there anymore mods i should do to help improve my quartermile time? battery relocation is in the works. anything else i may be forgetting in my list?
post #18 of 27 Old February 26th, 2012, 10:06 AM
LSX Freak's Avatar
It does change duration, but it's such a minute amount it really doesn't count for anything. I tried finding the thread on the corral but came up with nothin.
Engine bay is empty. Preparing for LS scumbaggery.
LSX Freak is offline
post #19 of 27 Old February 26th, 2012, 12:17 PM
If you do a cam above 500 you'll have to get new springs. Don't buy a ford cam
hedrick5286 is offline
post #20 of 27 Old February 26th, 2012, 12:41 PM
Shit man, Tmoss himself made something like 280rwhp with stock gt40ps/explorer intake, shorties and a degreed stock cam.
Other than the battery relocation you're doing now, I wouldn't mess with your setup. You have more than enough suspension work for a lower powered car. Shit, people with bone stock suspension and subframe connectors go low 11s.
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/251524-hp-quarter-mile-guess.html
HP and Quarter Mile Guess This thread Refback April 14th, 2012 07:55 PM
HP and Quarter Mile Guess This thread Refback April 14th, 2012 07:54 PM
