Steeda tri ax shifter??
Old June 12th, 2007, 03:59 PM   #1
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
Any of you guys running one of these? If so is it any good? easy to install or a pain? Found one for a pretty good price and it looks nice. If these suck let me know which one would be good and if there is alot involved to install one of these. Thanks
Old June 12th, 2007, 06:31 PM   #2
shurb125's Avatar
1993 Mustang LX Vert
shurb125 is on a distinguished road
I have on in a 93 LX vert and it wan't hard to install at all. I like it but I really don't have anyting to compare it to except for the factory shifter.
306 TFS heads stage 3 port & polished, TFS stage 2 cam, TFS Track heat intake, DSS pistons, 24# injectors, 76mm MAF, 70mm BBK/Edelbrock TB and spacer
Old June 12th, 2007, 08:52 PM   #3
jam77's Avatar
1987 Mustang GT
was there a big change in the throw? alot shorter?
Old June 12th, 2007, 09:01 PM   #4
JBIGBOOTSY's Avatar
1990 LX hatch
installs easy the tri ax is really "robotic" it's not soft anywhere keep it lubed up or else it rattles.
Old June 12th, 2007, 09:39 PM   #5
shurb125's Avatar
It was a big difference for me, alot shorter than factory for sure. It was worth the money.
Old June 13th, 2007, 09:11 PM   #6
jam77's Avatar
1987 Mustang GT
Well i decided to spend a little more money and buy a pro 5.0. I hope that was a good choice seemed to be more popular.
Threads Similar to: Steeda tri ax shifter??
Steeda Triax shifter mdvaldosta Parts 25 February 2nd, 2010 09:34 PM
steeda tri-ax or hurst shifter? 94pacecarSVT 94-95 11 July 26th, 2007 10:29 AM
steeda shifter adam0421 2005 - 2010 18 March 6th, 2007 04:42 AM
