Taking engine out
Old June 12th, 2007, 11:03 PM   #1
roscoe is on a distinguished road
Taking engine out
im taking the engine out next weekend, want to bore it out into a 306 or a 308, what do you guys think? what am i going to have to upgrade to make the bigger engine better (TB, heads, cam, etc...)? or can i use the stock stuff for a while?
Old June 12th, 2007, 11:35 PM   #2
If you have the motor bored, you will need new pistons, might as well get the whole rotating assembly....You could keep everything else stock if you wanted to, but dont have too obviously, A new top end kit (trick flow makes good stuff) would suit your 306 well...exhaust, gears, good sticky tires, suspension....I could go on forever.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old June 12th, 2007, 11:38 PM   #3
TurboLX's Avatar
1988 Mustang LX Turbo
a 306 is a 30" bore, i would go with a 347 stroker
Old June 13th, 2007, 01:50 AM   #4
347? i wouldnt mind but now your talking serious $$$$ and im planning on driving this thing to work, i drive about 15-20 miles each way, with gas the way it is now.... well you know.
Old June 13th, 2007, 02:11 AM   #5
how reliable is this combination, making a 302 into a 347 would i have any issues down the road?
Old June 13th, 2007, 08:53 AM   #6
92Rideagain is on a distinguished road
I would suggest a 331 stroker kit. The 347 causes a lot piston rock in the cylinder walls due to the extreme angle of the rod. This can cause early excessive wear and damage to the rings over time. The 331 has a decent displacement and has a good rod to piston to ratio so it does not have the rocking of the piston like the 347 does. Ronnie Crawford out of Florida made the 347 famous, there are quite a few daily drivers out there with 347's in them. In my opionion I would go for the 331. Call DSS, Coast High Performance, Kuntz Co. and ask the experts. Once you advise them of what you intend to do with the car they can recommend the best one for you. These forums are great but nothing can subsitute advice from the experts, the people buidling these kits day in and day out. They are helpful and do not mind discussing what will be more dependable based on your needs. Good luck.
Old June 14th, 2007, 09:53 AM   #7
bgddy50's Avatar
1991 LX Mustang
bgddy50 is on a distinguished road
Im runnig a coast high performance 347, and have no complaints. I called them myself about a 331 and decided on the 347. Smog legal at that! If you have the funds its well worth it.
CHP 347, AFR 185's, T-56, Maximum motor sport complete suspension, 3. 55 gears
Old June 14th, 2007, 10:37 PM   #8
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
Definitly just go with the 331 stroker the 347 has such a long stroke that it just isnt practical for the road.
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old June 15th, 2007, 05:45 PM   #9
I know more guys with 347s than 331s, and they are all daily driven...16 more cubes for the same amount of money...I am going 347 for sure.
[SIGPIC][/SIGPIC]
Old June 15th, 2007, 06:01 PM   #10
TurboLX's Avatar
my last one was a 347
Old June 17th, 2007, 03:07 PM   #11
P.O.S-GT is on a distinguished road
for something that you are planning on driving daily i would do the 331 stroker kit.
1990 GT HATCH
trw pistons/351 heads with all the goodies
schneider 260 cam/8.8 posi w/4:10's
1/4 mile unknown??? cause she wont start
Threads Similar to: Taking engine out
taking it all off ttop5.0 5.0 Mustangs 25 November 12th, 2008 09:53 AM
Taking off spoiler slrvstang2007 2005 - 2010 20 January 18th, 2008 08:58 PM
taking a vote!!! 2oo3c0bra 99-04 33 August 22nd, 2007 03:10 AM
Taking Down a GTO 2007calispecial Drag 35 August 17th, 2007 01:23 PM
Taking apart my Procharger Areteracing Modular Mustangs 1 January 21st, 2007 06:03 PM
