Help me pick a cam
Old June 13th, 2007, 12:04 AM   #1
wolverine8490 is on a distinguished road
Help me pick a cam
I need some help picking out a cam for my motor build. I am building a 91 5.0. Boring .30 over, using the AFR 165's, 1.6 roller rockers, and toping it off for now with a cobra intake system. What cam would you suggest I run. I am looking to try and push 400HP at the flywheel.
Old June 13th, 2007, 12:08 AM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
e303
Old June 13th, 2007, 12:15 AM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
youll need more than 165s for 400hp. For a cam, a custom grind is best, otherwise .5somthing lift, and 230somthing duration @ .050, 110-112 ls
Old June 13th, 2007, 12:21 AM   #4
Originally Posted by TurboLX
e303
Does summit sell the e303?
Old June 13th, 2007, 12:25 AM   #5
JBIGBOOTSY's Avatar
1990 LX hatch
yup, they sound good I think theyre .498 lift 220 duration for both int and ex.
Old June 13th, 2007, 12:26 AM   #6
It looks like the f303 meets the above requirments. Does that sound right?
Old June 13th, 2007, 12:31 AM   #7
Jay allen at camshaft innovations
Comp cams
cam motion
Ed curtis at flow tech induction
You will be surprised what a custom cam can bring you in HP...
But if you are going with an alphabet cam, the FMS B303 pulls harder up top than the E303, and sounds good in a well modded 302...That is what i am putting in mine here soon!
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old June 13th, 2007, 12:34 AM   #8
JBIGBOOTSY's Avatar
1990 LX hatch
Yea kinda, I have that cam it has a nice lobey idle and allows a little better reving, but with the combo listed I would go a LITTLE bit more race oriented. upper .550s mabe 230-240s duration the fms alphabet cams are a bit outdated.
Old June 13th, 2007, 12:40 AM   #9
So, from the stats that I have seen, it looks like the e303 if in the middle of the f303, and the b303.
Its not going to be a daily driver, but it also is not going to be a 1/4 mile car either. I want it to be driveable without any crazy issues.
Old June 13th, 2007, 12:46 AM   #10
Yeah i wasnt suggesting he even looks at an alphabet cam, just trying to give him some more info on the B cam
Wolvering: Dude, get a custom grind cam...You can tell them everything and they will make a cam for you. you can tell them how streetable you want it, how you might want it to lobe, and you fill out a spec sheet and you should have it in 2 weeks or so. From what i hear, it is money WELL spent.
[SIGPIC][/SIGPIC]
Old June 13th, 2007, 12:49 AM   #11
Great, thanks for the advice. I new to the ford world, and I just want to get the right combo to make everything work good. Believe it or not, I just sold my 95 M3 to build this mustang.
Old June 13th, 2007, 12:53 AM   #12
See that is where a custom cam will work great for you....It will be ground for your specific application...With other cams, you might have to work out some kinks.
Welcome to the mustang world. Kick your shoes on and stay awhile, you should fall in love with these car awfully fast!
[SIGPIC][/SIGPIC]
Old June 13th, 2007, 02:13 PM   #13
jazer is on a distinguished road
i run a b303 great cam up top but shes really lumpy at idel
Old June 13th, 2007, 05:50 PM   #14
That is the reason i bought mine
[SIGPIC][/SIGPIC]
Threads Similar to: Help me pick a cam
Help me pick out my new avie Drick The Clubhouse 21 October 21st, 2007 04:23 PM
tell ur GF to pick one of these... 97Cobra The Clubhouse 7 October 18th, 2007 10:38 PM
Help me pick my new mustang. ch4zl33 5.0 Mustangs 22 October 18th, 2007 01:09 AM
You have to pick a chick. JBIGBOOTSY The Clubhouse 15 October 5th, 2007 12:41 AM
Rim Pick-up joka187 The Clubhouse 16 June 19th, 2007 08:36 AM
