Discussing New engine 2k to spend what parts to get? in the 5.0 Mustangs Forum. Okay guys i have this engine brand new in my car...ive been workin my ...
Old June 13th, 2007, 02:24 PM   #1
MIGHTYJO3YOUNG's Avatar
1989 mustang Lx
Okay guys i have this engine brand new in my car...ive been workin my ass off and now i finally have some money saved up. Im lookin to get intakes cam and heads all at once. I have about 2k that i want to spend and i have these heads in mind because of the reasonble price...they also seem like good heads but then again i dont know much...heres the link for them http://cgi.ebay.com/ebaymotors/Ford-...mZ320118034394
I was thinking of a cobra intake upper and lower...and then a x303 cam. I have that engine already along with shortys heads flowmaster american thunder exhaust and 3.73 gears in the rear. With the x303 it warns about piston to valve clearance do u guys think ill have a issue with that? if so what do u think is best for what im looking for and i have. My car is a every day driver but i want it to be a beast. Thanks for the help!
[Jasper Performance
Products
“Class II Version - Ford 302”
280 hp (approx.) @ 5000 rpm • 315 ft. lbs. Torque @ 3900 rpm
good low speed torque
• O.E.M. replacement
Part Specifications:
• Approximate 8.75:1 compression ratio
• High performance rod bolts and nuts
• High rev lifters and performance valve
springs with retainers
• Double roller timing set
• Flat top hypereutectic pistons and moly rings
• Harmonic balancer
• High performance valves
• Class II camshaft
• High performance bearings
• High performance head gaskets
Machining Specifications:
• Kolene Salt Bath cleaning
• Three angle valve seat machining
• Precise surface finish measuring
• Square decking of block
• Main saddle align honing
• Electronically balanced engine assembly
• Torque plate honing
• Computerized boring
• Precision crankshaft machining, oil hole
chamfering and polishing
• Live testing
Camshaft Specifications:
• Hydraulic Camshaft
• .050 Duration: 214° Intake; 224° Exhaust
• Advertised Duration: 280° Intake; 290° Exhaust
• Cam Lift: .295 Intake; .310 Exhaust
• Valve Lift: .472 Intake; .496 Exhaust
• Lobe Center: 107° Intake; 117° Exhaust
Camshaft Range Guide and Recommended
Equipment:
• Fair idle with lope
• Operating range of 2000-4800 rpm
• Good midrange torque and response:
2400-3200 rpm range
• Good fuel economy with recommended equipment
• Good highway towing with correct axle ratio
• Mild bracket racing suitability
• Stock automatic or manual transmission compatibility
• Recommended 3.70:1 axle ratio or lower
• Stock or aftermarket 2 plane or torque type intake
manifold recommended
Old June 13th, 2007, 02:34 PM   #2
1992 mustang LX
7.21 1/8 mi
when i got my heads, i noticed they were lighter but the air flow
looked about the same. i had a machine shop look at them and
he found me another 50hp by porting em.
c'mon sunshine !!
http://i29.tinypic.com/2eq9zy9.jpg
Old June 13th, 2007, 06:06 PM   #3
fogged306's Avatar
89 GT
With that low compression ratio, I'd throw some boost at it instead... just my .02
Old June 13th, 2007, 06:42 PM   #4
get the trick flow complete kit. and get the high port heads if you can. i think they say its over 350 hp. and just over 2200$
Old June 13th, 2007, 11:08 PM   #5
Leave the motor alone. That's what I would do. If you have a T5 you are at the breaking point as far as TQ goes. I would take the 2000 and upgrade my tranny and/or suspension. Get an aluminum d/s and/or some lighter wheels. 280 hp and 315 ft lbs of tq is nothing to sneeze at. Especially for a daily driver.
2007 Explorer Sport Trac, 292 HP, Stock
Old June 14th, 2007, 08:16 AM   #6
JBIGBOOTSY's Avatar
1990 LX hatch
with a 2.055 intake valve and flat top pistions, unless theyre notched for that exact valve size, youre gonna fun into trouble... for sure.
Originally Posted by HELLRAZR94
what up pussy lets stop talking shit i would love for your pussy ass to come to cali so that i can show you what im about, when you get here let me know and i will come to you fag
Threads Similar to: New engine 2k to spend what parts to get?
Engine Parts sn94 Want to Buy 3 November 20th, 2007 06:41 PM
WTT: Engine For Parts TurboLX Trade 2 November 15th, 2007 04:35 PM
perfomance engine parts kreil45 Engine 8 July 4th, 2007 08:37 AM
Lots of engine parts from a 86 GT TtopFoxRod50 Engine 0 March 22nd, 2007 01:59 AM
FS: PI cams, 5.0 engine, 289 parts, 68 dlxcoupe Engine 0 January 26th, 2007 02:18 PM
