lower intake gasket
Old June 13th, 2007, 06:37 PM   #1
1989 GT Hatch
YNOT is on a distinguished road
lower intake gasket
do you guys use those little gaskets for the front and back of the lower intake, or do you not use them and just bead liquid gasket there? the reason i ask is on chevy's those little gaskets don't hold and every just uses liquid gasket or whatever in there place.
i have a 1989 stock 302 that i am adding a trick flow upper and lower to.
Old June 13th, 2007, 08:09 PM   #2
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
lower intake gasket
I used the black rtv instead when i installed my typhoon intake and it worked really well. Everyone i talked to and the articles i read said to not use the gaskets.
Threads Similar to: lower intake gasket
Question about intake gasket causing pinging. please help. 04silversnake 5.0 Mustangs 2 October 18th, 2007 04:50 PM
lower intake patwrecked 5.0 Mustangs 8 October 9th, 2007 08:50 PM
Intake Gasket 1bad5.0 5.0 Mustangs 4 September 19th, 2007 02:33 PM
lower intake 02ponypackage V6 Mustangs 2 August 15th, 2007 08:30 PM
Need help using a 5.0 upper intake on a 5.8 lower intake Washington5.0 5.0 Mustangs 4 March 9th, 2007 01:54 AM
