1988 Mustang Gt Few questions before i buy.
Old June 14th, 2007, 12:40 AM   #1
88stang_dreams is on a distinguished road
Hey im looking at buying this 88 gt and had a few questions on what to look for and just general stuff about them. Let me first say im new to mustangs but not cars so ill be asking a lot of questions and hope yall can answer most of them. On to the car now
It does have a salvage title owner said in was in a front end collison but everything is replaced. heres what it has
v-8 306
377 gears
underdrive pullys
24 lb injectors
powdercoated 10 hole rims
Cobra clutch
T-5 tranny w/ app. 200 miles on it (rebuilt)
Hurst short throw shifter w/ t handle
5" monster tach
Recently replace rack & pinion
bbk headers
bbk h pipe
spintech mufflers
The owner says that The injectors are a bit large and feed too much fuelto engine. Would the fix be to get a bigger maf that is made for the 24lb ones? if not then what would i need besides stock injectors?
How can i tell on the 88 gt if the cylinder is washed out? (compression test?)
What all should i look for before buying it? and is it worth 2500 or should i offer him 2000?
Thanks in advance to the people who read the whole thing and answerd my questions
Jon
Old June 14th, 2007, 01:29 AM   #2
neverfastenough1's Avatar
I personally, which means this is just my opinion before anyone jumps on me, would not buy a salvaged titled vehicle unless...1. I saw the damage before it was fixed so I could tell the extent of the damage....2. I took it to get it looked at by a body shop because I am not a body expert.....3. I was planning on getting two and transplanting the stuff from the wrecked one to a known good one. If everything else is in god shape I would say it is a good price even if you had to spend 1000-1500 on a roller to transplant it to. IMO You could do a compression test or a leak down test. Yes, your MAF should be calibrated for 24lb injectors, but maybe someone else can say something on that issue. Welcome to the site!
Old June 14th, 2007, 08:18 AM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
whats a 3.77 gear?
Old June 14th, 2007, 09:44 AM   #4
fogged306's Avatar
89 GT
Originally Posted by JBIGBOOTSY
whats a 3.77 gear?
I agree with neverfastenough1. With a salvage title you don't know what you are getting into. Unless it was a water damage or theft salvage. If you do decide to go for it, I would get it on a frame machine and check for straightness, it could dogwalk or worse and you would never know from just looking at it while it is just sitting there.
Old June 14th, 2007, 04:37 PM   #5
ryans88gt's Avatar
Does it have a mass air meter? Only California 88s came with mass air from the factory and those are pretty few and far between. If it has the cobra mass air upgrade that came with 24 lb injectors the MAF would already be the correct calibration.
I would definitely worry about the salvage title, but $2500 is cheap for a car that runs and looks decent. A good place to look for front end damage is inside the hood area where the fenders bolt up. Also check that the doors are straight with the rest of the car and open and close without rubbing. Any problems there and the car might have more serious frame damage that wasn't fixed.
Old June 14th, 2007, 09:24 PM   #6
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
I wouldnt even mess with something that had a salvage title that means it was most likely totaled at one time
Ryan is right only the 88 Mustangs that were delivered to a california DSO came with mass air so if it is not a California car then it does not have MAF it has speed density. Unless it has the mass air conversion already done to it
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old June 16th, 2007, 10:41 PM   #7
yeah i plan on fixing the speed density to a maf(75mm) first. Then go with gt40 heads and a stage 1 trick flow cam. I should be picking it up tommorow if all goes well and looks good ! i cant wait. how bad do you think it would be on the motor to drive it for like 45mins of it running rich? right when i go pick it up should i advance the timing? it has 24lb injectors on a speed density.
Old June 17th, 2007, 06:25 PM   #8
Drick's Avatar
It wouldnt hurt anything it will problly run like crap and you could foul some spark plugs
FX4 Crew
Crew member #1
Old June 18th, 2007, 02:04 AM   #9
How'd the trip go?
Old June 18th, 2007, 08:01 AM   #10
TurboLX's Avatar
1988 Mustang LX Turbo
whats a 3.77 gear?
just like he said the mustang had an ECM
Old June 19th, 2007, 12:03 AM   #11
Well im the new proud owner of a stang the ride was all right. It was real laggy in first but im sure it was cause of the extra fuel it was dumping. well i already order a stick ecm, pro m 75mm maf and maf harness. cant wait for it to come in so i can hook it all up along with a msd 6al and new coil ill take pics.
Old June 19th, 2007, 12:33 AM   #12
Congrats! Now where are the pics???
Threads Similar to: 1988 Mustang Gt Few questions before i buy.
hey all 1988 mustang gt 1BADSTANG 5.0 Mustangs 10 September 17th, 2007 08:34 PM
1988 Ford Mustang GT Convertible Mustang Problems ridebmxfbm 5.0 Mustangs 18 May 14th, 2007 01:35 PM
1988 mustang gvw dr.gonzo! 5.0 Mustangs 10 February 21st, 2007 11:19 AM
