turning up fuel press.
If you turn up the fuelk pressure does that help any and if so how much should you turn it up.
1990 LX hatch
On a maf car it only helps when your injectors are getting close to being maxed. Ona s/d car it helps after a few bolt-ons. usually 2-5 psi increase seems to be the norm.
1987 Mustang GT
base is 39psi i have played with my pressure and i found it works best at about 41 psi and gives me a good a/f ratio.
Threads Similar to: turning up fuel press.
| R 04 PI Cam Gears Press on or Bolt On? | G.T. Rags | Modular Mustangs | 9 | October 25th, 2007 08:41 AM |
| and I thought it was a press to test! | WAR-PARTY | The Clubhouse | 5 | July 30th, 2007 09:11 PM |
| oil press. | terribleonexx88 | 5.0 Mustangs | 12 | July 15th, 2007 10:04 PM |
| LAg when I press the gas | nHuman | 96-98 | 7 | December 25th, 2006 02:41 PM |
