Squealing noise
Just got my stang running after i replaced the flexplate and converter... now i have a new problem... when the car is in drive and i accelerate it makes a terrible squealing noise... it has to be something from the tranny be cause it only does it when in drive and moving... i cant out it in drive with my foot on the brake and revv it up and it makes no noise... a buddy said it might be the u-joints on the driveline... and i was wondering is there a certain way im supposed to adjust the shifter cable when bolting it back to the tranny?? Any ideas what this noise is?
I highly doubt it's anything with the u-joints or the driveshaft. Are you getting any vibration?
sounds like the driveshaft is hitting the mufflers or something else.
Nope no vibrations... it only does it when i have im pushin the gas though so i dont think its hitting the mufflers... it seems to only do it between the 15-2500rpm range... i know my tanny mount is all torn up... gettin a solid mount soon.. but could it possibly be the tranny slumpin when i gas causing the driveshaft to hit the exhaust? It does sound a little more towards the front of the tranny but its hard to tell from inside the car
well nevermind the muffler hitting the driveshaft theres a solid inch and a half of clearance between them
Could be u-joints. Its common for u-joints to squeal when they are old and abused. The bearings dry out and they squeal.
1997 Mustang Cobra
1/8 - 8.89@86mph
![]() iTrader: 1 reviews
It could be the acc. belt. my jeep did that and i thought it was the tranny or transfer case all the time and it turned out to be the strain from the aulternator, and it always did it while in drive. hope this helps any.
![]() Modifications and pics in my Garage... Reps Appreciated!
im gonna take it into work probly tomorrow and put it up on the lift and see if i can find out where its coming from... I really dont think its the belt or pullies because its definitely comin from underneath and i put some dressing on the belts
1997 Mustang Cobra
1/8 - 8.89@86mph
hmmm. you might want to check the axel to while your under there.
1999 Ford Mustang V6
so did you do this converter and flexplate yourself or did you take it to a shop? what's the fluid level like on your trans?
...even fire and single cammin 1986 Ford F-150 5.0L 2WD 1994 Toyota Pickup 2.4L 4WD 1999 Ford Mustang 3.8L V6 2002 Jeep Grand Cherokee 4.0L 2WD 2008 GMC Sierra Denali 6.2L AWD |
Did it myself... fluids full... i been checking it daily since i put the tranny back in
i would put it in park, and rev the pedal with my hand looking under the car, then rev it using the throttle body to help figure out where it is coming from if you don't have a friend to help.
It really sounds like its comin from the converter... i was told to put one quart in before i reinstalled it but i know it hold A LOT more than that... do you think the converters low on fluid??? How would i fix that if thats the problem
#14 | |
Another thing it could be is the governor assembly in the tailshaft of the transmission. I blew apart a C4 once that was making a squealing nois that I couldn't find. The governor assembly let loose and blew the tail housing apart.
Before i took it out the dipstick always said it was overfull... now its right at the X's where it says do not add.... should i maybe put in another quart or maybe even just a pint? I dont want to overfill it
I really gotta figure this out i cant take it any more.. It actually does it in park when i rev it up past 2500 it does it only when it winds down... but in drive it does it whenever i accelerate... but only between 15-2500rpm.. Im about reqady to just start dumping fluid in to see if it stops so if anybody has any more ideas please feed me
Well i put the car up on jacks and put it in drive... made no noise i had it at like 5000 in drive and it made nothing... it only makes the noise on the ground moving between 1500 and 2500 RPM... WHAT THE HELL IS GOING ON?!?!?!?!?
did you ever figure out what the noise was? I'm having the same problem and its annoying as hell. No vibration either.
Tired 200xxx mile 91 LX 5.0, BBK CAI, 70mm Throttle Body, Under Drive Pullies, BBK Shorties, MSD Wires and Coil, Electric Fan, Custom X-Pipe, Pypes Violators Dumped |
Threads Similar to: Squealing noise
| Squealing Engine | mustang17 | V6 Mustangs | 6 | November 13th, 2007 11:51 PM |
| squealing from the rear passenger side.. | VIXEN_GT | 99-04 | 2 | July 17th, 2007 06:59 PM |
| noise | cali 5.0 | 5.0 Mustangs | 2 | July 12th, 2007 10:02 AM |
| 2005 auto mustang vibration noise/ rumbling noise | ozan169 | 2005 - 2010 | 4 | March 13th, 2007 05:31 PM |
| Another noise 8( | flattusmaximus78 | General Tech | 1 | January 30th, 2007 04:11 PM |
