Hold Down???
Old June 15th, 2007, 01:06 PM   #1
jonnotch is on a distinguished road
Hold Down???
Does anyone have problems with your distributor loosening up? Also does the distributor seat and/or rests on block where the hold down is? Or does it rest on the oil shaft?
Thanks
jon
1992 Mustang Notchback-306, road race project.
Old June 15th, 2007, 01:08 PM   #2
shudahadav8 is on a distinguished road
the base of the distributor shoud rest on the block, not supported by the oil pump shaft. Sounds like you have the wrong distributor or your not getting it fully seated.
Old June 15th, 2007, 01:25 PM   #3
skid6 is on a distinguished road
the base of the distribuer might be to wide and not sliding in yes the it sit over the oil pump shaft but it does not support it is it slipping in all the way with the cam gears
Old June 15th, 2007, 01:25 PM   #4
Old June 15th, 2007, 01:53 PM   #5
5literJeff is on a distinguished road
Send a message via AIM to 5literJeff Send a message via Yahoo to 5literJeff
When I converted my car to carb and changed to an edelbrock intake, I could not use the factory distributor because it was too wide to fit on the edelbrock. Ended up going with a mallory distributor instead.
Threads Similar to: Hold Down???
Will it hold Bigg_Nate V6 Mustangs 8 September 27th, 2007 08:55 PM
Why can't v8's hold as much? AnglicoGT98 The Clubhouse 46 September 20th, 2007 06:55 PM
how many quarts does 5.0 hold j2000_guy 5.0 Mustangs 4 August 22nd, 2006 01:37 PM
