Eaton m90 on foxbody - Forums at Modded Mustangs
post #1 of 82 Old March 25th, 2012, 03:36 AM Thread Starter
ReefBlue1994's Avatar
So I picked up an eaton m90 supercharger with a custom made adapter plate and matching TB kit for 450$ off of corral,sounds pretty cool right?haha.im going to be doing a build with this,I'm wondering what a good head and cam combo would be with this,the supercharger only pulls about 5 lbs of boost,I didn't want to risk blowing the stock bottom end.
Sent from my Autoguide iPhone app
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong.
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
NEWEST ADDITION: Eaton M90 supercharger kit
ReefBlue1994 is offline
post #2 of 82 Old March 25th, 2012, 03:50 AM Thread Starter
And should I get it ported?
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #3 of 82 Old March 25th, 2012, 12:24 PM
ryanw's Avatar
By the time you get that thing running right you will have spent the same as a used vortech supercharger, and vortech would have made more power.
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
ryanw is offline
post #4 of 82 Old March 25th, 2012, 12:41 PM
I need a 5 lug kit
Ninety3Coupe's Avatar
Uh-huh... Ryan's right. I hate to say it, but we have watched this build before. Couple times even.
Don't get us wrong, if you have the fabrication skills, money, patience and time you are gonna have a very cool, different item - for sure. But even with the "adapter plate", you are going to spend a lot of time and money on this and again to underscore Ryan, it will be the same money as a used Vortech and the Vortech would have made more power.
Whatever you choose we wish ya luck dude! Post pics.
Half of Maximum Motorsports Catalog, Full Intake, Full Exhaust. Needs paint and $35,000 in mods. Car / Build Photos: http://photobucket.com/CoupePictures
Ninety3Coupe is offline
post #5 of 82 Old March 25th, 2012, 02:26 PM Thread Starter
No it's a complete setup!haha it's already running and it bolts right onto a stock lower intake manifold
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #6 of 82 Old March 25th, 2012, 02:37 PM Thread Starter
Originally Posted by 1990fox5.0 View Post
hi, i made a kit to bolt an eaton m90 onto a stock foxbody lower intake manifold. the m90 outlet has been ported and has a smaller pulley on it. kit works great and sounds awesome boost gauge shows 4-5 psi of boost. everything works great blower has a new snout seal and oil. this kit was made carefully and everything works great, you would still need injectors and a maf or if needed i have an fmu that i could give with the kit. make me an offer, the blowers worth at least 100 bucks and the rest of the kit is custom so make offer. tb is mounted in stock location so no changes are needed to throttle cable or tv cable. egr spacer can be used but doesnt have to be. all bolts, braces, idler pulley, and belt will be included, however if you have a stock tensioner you may need a different sized belt. i will try to upload pictures and videos of it running but if the links dont work, txt me at 7083105782 and i can send you pictures and or videos. email gearhead54@gmail.com or txt with questions or offers. will ship at buyers expense. thanks
http://i1226.photobucket.com/albums/...1/IMAG0196.jpg
http://i1226.photobucket.com/albums/...1/IMAG0201.jpg
http://i1226.photobucket.com/albums/...1/IMAG0200.jpg
http://i1226.photobucket.com/albums/...1/IMAG0198.jpg
http://i1226.photobucket.com/albums/...1/IMAG0077.jpg
http://i1226.photobucket.com/albums/...1/IMAG0158.jpg
http://i1226.photobucket.com/albums/...1/IMAG0185.jpg
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #7 of 82 Old March 25th, 2012, 02:55 PM
ryanw's Avatar
Wow, thats different.
Seems like theres not much space for boost in between that lower intake adapter plate.
255 fuel pump,
3:27 gears
ryanw is offline
post #8 of 82 Old March 25th, 2012, 02:59 PM Thread Starter
Haha tell me about it.guess we will see how it works,either way it was really cheap power.just thought it was a cool idea
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #9 of 82 Old March 25th, 2012, 03:18 PM
ryanw's Avatar
Dont forget to upgrade your injectors and fuel pump.
Im guessing that with that set up 30 lb injectors will be all you need
255 fuel pump,
3:27 gears
ryanw is offline
post #10 of 82 Old March 25th, 2012, 03:19 PM
98SnakeHorse's Avatar
thats different. Hope that works out for you
"The Names Nick"
1998 Mustang Cobra [Sold]
2000 Mustang Gt Built/Blown [Sold]
1995 Mustang Gt Built/Blown [Part-Out]
1997 Toyota Supra Na to Na-t [Sold]
1998 Mustang Gt Stock PI Swap (Budget Blue)
98SnakeHorse is offline
post #11 of 82 Old March 25th, 2012, 03:26 PM Thread Starter
Yeah I was thinking maybe cobra injectors,those are 24lb...not enough?and what fuel pump should I go eith
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #12 of 82 Old March 25th, 2012, 03:27 PM Thread Starter
And how much horsepower do you think I'll gain just from the blower?
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #13 of 82 Old March 25th, 2012, 03:30 PM
ryanw's Avatar
255 lph fuel pump.
You might be fine with 24s but 30 i think would be better, and when i said 30 that was a guess. But im willing to bet that, is close to what you want.
I have no clue how much power that thing will make. Maybe 50 hp... i dont know
255 fuel pump,
3:27 gears
ryanw is offline
post #14 of 82 Old March 25th, 2012, 03:34 PM Thread Starter
Haha if it all works out 50 hp for 500 bucks isn't too bad.what heads and can would you guys reccomend pairing with this?i was thinking twisted wedges but idk about the cam....
And I'm still trying to figure out what hood to do...I dont think it will fit under a cowl because it's off centered
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #15 of 82 Old March 25th, 2012, 11:50 PM
13.2@102.5
Z)OoM's Avatar
I've been looking into those setups! Very unique!! There was one here running in mid-michigan, he ran high 12's with 4.10 gears i believe. Can't help you on the heads/cam combo, but I'd like to see this when its finished
Z)OoM is offline
post #16 of 82 Old March 26th, 2012, 09:27 AM Thread Starter
I will start a thread if it all works out it will be an extremely cheap build and definately unique. Glad to see someone interested,my first big project!
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #17 of 82 Old March 26th, 2012, 11:41 AM
MIGHTYJO3YOUNG's Avatar
I'm doing the same thing, but with a blower from a GT 500. Mine is just taking me months to get done unfortunately.
1992 5.0 lx_soon to be powered by a m122 GT500 supercharger
MIGHTYJO3YOUNG is offline
post #18 of 82 Old March 26th, 2012, 12:49 PM Thread Starter
yeah i bought mine complete, i still need to figure out my cam/head combo to go with that F/I
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
post #19 of 82 Old March 26th, 2012, 01:34 PM
StangBanger302's Avatar
A cheap/decent head/cam combo for your car is limitless since you're going boost. Boost makes up for inefficient parts.
Used Trick Flow 170 heads and an Anderson B-31 cam. That'll make more than enough power and it'll be stout!
N/A or N2O Iron headed SBF coming summer 2015....Long ass build
StangBanger302 is offline
post #20 of 82 Old March 26th, 2012, 01:45 PM
ryanw's Avatar
My fuel injector recomendation was based on you using stock heads, so its possible you may need to go bigger, and get the car tuned
255 fuel pump,
3:27 gears
ryanw is offline
Human Verification
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/255575-eaton-m90-foxbody.html
The Official Boredom Chat Thread - Page 101 - Ford Forums & Technical Discussions This thread Refback July 6th, 2014 08:06 PM
The Official Boredom Chat Thread - Page 101 - Ford Forums & Technical Discussions This thread Refback July 6th, 2014 06:17 PM
Eaton m90 on foxbody This thread Refback December 5th, 2012 09:37 PM
