Please Help Cant Get My New Motor To Fire!
ok i have been trying to get this thing going for a very long time now. cannot get this thing to start to save my life. i have spark and plenty of fuel but just yesterday i decided that i would pull an injector to see if it was spraying and got nothing. does it sound like something is disconnected?
1990 GT HATCH trw pistons/351 heads with all the goodies schneider 260 cam/8.8 posi w/4:10's 1/4 mile unknown??? cause she wont start |
Are your injectors plugged? You can pull them apart and check but try not to break the pintle cap on the end. You can alos send them out to a place called Midwest Injectors or someplace like that and they clean them and make them good as new for about $11 per injector plus shipping.
i was thinking that until i checked all 8 and even switched them out with a new set of 36lb. blue tops. I am really not liking ford
are you gettin fuel to the logs or just from the pump? is the motor cranking? whats it sound like?
im getting fuel up to the injector. the motor has a new battery and starter so it spins very well and sounds like an engine thats just turning over
might be a computer problem then
yea may be but would like to eliminate everything else before I go spend some cash on a new ecm
dont have to just get a new comp....run the check engine light test i think neverfastenuff knows how to do that....
If you got spark and fuel it sounds like a timing or misrouted plug wires. I don't know if you will be able to pull codes if you can get it started but here's the test. Which fuel pump do you have and whats the pressure regulator set at? Thats some big squirters.
http://fordfuelinjection.com/?p=13
all motor
92 coupe
9.94@136.40
buy a noid light and see if the signal is there
#11 | |
ok went out and tried to play with the car and finally after 5 months of playing with this thing got her to fire, runs like ass, tried both firing orders and it still runs like crap. all the tubes on the headers are warm except for #6&8 are very hot. any thoughts?
gotta be something to do with the timing....what are you set at?
right now its about 12
89 GT
Are tubes 6 & 8 glowing at all? It is either running rich or like gunner said the timing. Are you going by the timing marks on the balancer? if so they may be off if it is a stock one, the rubber bushing inside the damper goes bad and it shifts causing the marks to be off. I'm also inclined to think that the firing order is off if you are just getting 2 tubes hot. Sounds like it is firing with the exhaust valves open.
yes i am going off the dampner it is the ford racing one. the motor was just rebuilt and seems to have lots of compression but im going to go get a compression tester to make sure. the wierd thing is that it is running the same on both firing orders. pulled the plugs and they all still have some fuel on them except for 6&8 have carbon? if some one has an idea im a 100% open to it :wink
did a compression check and went like this!
#1 - 0 #2 - 0 #3 - 0 #4 - 0 #5 - 0 #6 - 120 #7 - 0 #8 - 120 could it possibly be the valves or something in the head? or does the compression only do the rings?
well either way make sure its the correct firing order for your setup...when you say it runs like crap what does it sound like its doin?
#19 | |
all motor
92 coupe
9.94@136.40
#20 | |
Threads Similar to: Please Help Cant Get My New Motor To Fire!
| Fire In A 66 | 460brevill | Classic Mustangs | 10 | December 3rd, 2007 11:46 PM |
| Fire came out of my tailpipes!?!?!!? | Jeff99gt | 99-04 | 35 | June 10th, 2007 11:32 AM |
| I Have Spark But My Car Won't Fire Up... | proszell | 2.3 Mustangs | 17 | May 3rd, 2007 08:12 PM |
| Engine on Fire! | WAVEBYE | Pictures | 18 | March 6th, 2007 01:52 AM |
