Is boring .30 over worth the money
I am going to drop off my 302 to the machine shop on Tuesday this week. Is it worth $140.00 to bore the block out .30 over if it does not need to be bored? Is the power increase worth it?
I couldnt notice any "power" from it, but it is a good choice for 100,000+ mile motors, and will be a nice clean up for it...I would do it, but of course you need different pistons after boring.
Yeah, I have a block from a Mountaineer, and it is in great shape. I dont know how many miles are on it, but you can still see the cross hatch from the original boring. There is no lip that needs to be reamed out. So I "think" I could go with factory pistons. I am using new pistons no matter what I do. I just want to see if the $$$ - HP would be worth it.
if your block is good i wouldnt do it
boring the block is not to give you more power , it is to clean up the bores. so if you could get away with a dash hone then thats what i would do. because later on the block can be bored over if needed without going too far into the walls.
1990 GT HATCH trw pistons/351 heads with all the goodies schneider 260 cam/8.8 posi w/4:10's 1/4 mile unknown??? cause she wont start |
Big timin' in a small town
If the block is still good dont bore because anything can happen and if you dont leave any play room in the cylinder walls you could wnd up buying a new block if something were to happen
#7 | |
Re: Is boring .30 over worth the money
Awesome, thanks for the info. Not only that, but it will save me 140 bucks
. I am still going to get them to check it out, and if they feel they need to bore, then thats cool. But it looks and feels to be in awesome shape.
1987 Mustang GT
the machine shop will be able to measure the cylinders and see how worn they are with a bore gauge. If they hone it and it doesnt clean up i would bore it you can usually go as small as 20 over and as high as 60. i would not get cheap at this point if it's even slightly questionable id bore it
sounds like all you need to do is get it honed out unless there is some actual scarring in the walls. if not your wasting your money
thining about doing the same thing
yeah i was thinking about doing the same thing but then i changed my mind and am going to buy a 351 and put a strocker kit in it picked up the motor today going to stroke it out to a 406 ci
#12 | |
Re: thining about doing the same thing
IM NO PRO BUT BORING OVER DOES UNSHROUD THE VALVES WHICH=MORE HP,REALLY PROBABLY NOT NOTICABLE,DEPENDING. IF ITS STOCK ID SAY JUST CLEAN IT UP, IF YOU HAVE HEADS AND CAM BORE IT,BUT LIKE MENTIONED DONT BORE TOO MUCH,....JUST MY STUPID OPINION...LOL
#14 | |
#15 | |
k sorry bout the caps,have to do it at work...lol,but yes darell unshrouding even .30 does help airflow,not noticable on a stock motor tho.Hey Darell,whats up with 41?
RUN WHAT YA BRUNG,HOPEFULLY DONT TOW IT HOME 93 GT AOD(SLUSHBOX)HA HA 3.73,TSI TRANZ,306,BENNETT HEADS AND CAM,ALUM SHAFT...BLAH BLAH BLAH |
#17 | |
Resident Bubblehead
i'm having my block bored 0.020" over when it gets rebuilt next week. it's got over 100k miles on it, and it's really just to clean the cylinder walls up some. i actually did the math, just out of curiosity and found that boring 0.020" over will net me about a whopping 2 hp while bumping the compression ratio from 9.7:1 to 9.8:1. i imagine going 0.030" over wouldn't be more significant than 0.020" over...
You'll definitely get more out of higher compression pistons than boring .030 over. Just boring it won't do squat performance-wise. You just do it so you don't have to buy a new block at re-build time and then you only do as much as necessary to make the cylinders round and straight without scoring. I wouldn't bore that block unless the cylinders are out-of-round or something. Just cross-hatch them. Save boring for after you try to re-use the wrist pin retainers.
Aren't there ten over pistons available?
1986 Mustang GT |
Anatidaephobic
not sure but don't most 347 stroker kits require the block to be bored .030?
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!!!!! |
Threads Similar to: Is boring .30 over worth the money
| worth the money | greyauto02 | V6 Mustangs | 17 | October 9th, 2007 02:47 AM |
| Is this tuner worth the money? | Smoothgrandmama | 99-04 | 4 | August 17th, 2007 12:52 PM |
| Port & Polishing worth the Money | NTHE11s | Modular Mustangs | 15 | May 12th, 2007 03:30 AM |
| Is it worth the money? | whtpny | General Tech | 12 | March 11th, 2007 11:26 AM |
| Is this worth the money? | 00SoSlow | V6 Mustangs | 4 | August 4th, 2006 04:12 PM |
