werid idle
well i did the whole reset your idle.......wow that was dirty :wink and now when ill rev it up it will stop at 1100ish for a couple seconds and drop to idle around 800. and when im driving and put it in to neutral then coast to a stop, it wont go to idle until im stoped. now is it sposed to be like this? or what could i do....
I just read an article about the dangers of drinking ... And it scared the crap out of me. So that's it............... After today, NO MORE READING. |
#2 | |
Re: werid idle
i have an lunati cam - its like the ford e303.
#4 | |
#5 | |
I'm having the same rolling idling issue with my 94 Cobra. What EFI components could cause this effect? Also, because of the cam, I don't think I can set the idle below 800 rpm without it running really rough.
Also, when I start the car when it is cold, it surges violently for about a minute. When the car is all warmed up when I start it, it doesn't surge.. The dude I bought the car from said it has a "closed circuit tune," or something to that effect and it will do that. Does this sound right? The cobra is pretty heavily modified. other than that, the car runs really well. any help would be greatly appreciated.
1992 Lx
11.39@119.24
its supposed to idle a lil higher till you stop, keeps vacuum high enough so ur brakes keep working and so the car wont die, my 93 does it, my 94 did it
It's really supposed to idle around 11-1,200 rpm until a complete stop? Just seems kinda high.
i have been learned i been putting my idle at 1000 in park, ill fix that. i learned something new.
matt |
#9 | |
1992 Lx
11.39@119.24
thats what mine does but it idles kinda high normally so the increase is just based off that, since ive put my cam n shit it doesnt really idle higher when ur slowing down and you can feel the pedal get firmer under ur foot and its harder to brake
2002 Gt
Not Slow
![]() iTrader: 1 reviews
they all have the wierd idle coming up to a stop.. when mine is stopped it idles flawlessly(after i did the idle reset) at about 650rpms,. now if im coasting to a stop it will not be at 650 it be around 900 ish, with a slight fluctuation.
2k2 Gt Eibach pro kit, bbk cold air, exhaust, 4.10s, 6k hid's |
Threads Similar to: werid idle
| idle help? | bone_crusher | V6 Mustangs | 5 | August 18th, 2007 02:59 PM |
| Werid problem wit my 6er | Timmano | V6 Mustangs | 29 | July 11th, 2007 07:24 PM |
| werid noise | wadepetersen | V6 Mustangs | 9 | June 28th, 2007 04:28 PM |
| idle...... | sivart | 5.0 Mustangs | 4 | April 26th, 2007 01:09 PM |
| Idle Problems Code 1506, Idle Overspeed Error | jagstang96 | 96-98 | 3 | August 29th, 2006 04:11 AM |
