engine block
Old June 17th, 2007, 10:55 PM   #1
88mstang is on a distinguished road
engine block
i just bought a 91 gt and the guy that built the car said it had the block out of a 69 or 70 mustang. is there a power handling differance between the older blocks and the block that should have come in the car. if so about how much?
Old June 17th, 2007, 11:19 PM   #2
NottyBoy93's Avatar
1993 Notch, 1988 Notch
NottyBoy93 is on a distinguished road
Darrell would probably know better than I, I think he is running a retro block, but basically the blocks are somewhat stronger, there will always be an issue with main cap flex though on the two bolt main blocks regardless of age. That inevitably is the weak link.
Old June 17th, 2007, 11:47 PM   #3
HACKGT350 is on a distinguished road
it should also be a flat tappet cam now instead of a roller, unless he did the conversion
Old June 18th, 2007, 12:50 AM   #4
neverfastenough1's Avatar
Did he say whether it was a four bolt or two bolt? The Boss engine was out in '69 & '70.
Old June 18th, 2007, 12:52 AM   #5
NottyBoy93's Avatar
Doesn't appear as though he had. That is why I made the caviat about two bolt mains. If it is an original boss then FTW
Old June 18th, 2007, 03:05 PM   #6
the guy that had the car built really couldn't tell me much all he did when he had the car built was wright the check. all he could say was it was out of a 69 or 70 and that it had a roller cam in it
Threads Similar to: engine block
99-04 GT engine block 00GT 99-04 19 July 10th, 2007 08:42 PM
Mach 1 engine block? JAY'SRED02 99-04 12 June 4th, 2007 02:23 PM
3.8l engine block 98Stang V6 Mustangs 3 January 31st, 2007 10:56 PM
Sandblasting the engine block.... DSEZ V6 Mustangs 4 January 26th, 2007 05:44 PM
