Discussing does anyone use water wetter from red line in the 5.0 Mustangs Forum. hey have any of you guys used water wetter in ur 302 and if so ...
Old June 18th, 2007, 01:32 AM   #1
hey have any of you guys used water wetter in ur 302 and if so was it worth it
Old June 18th, 2007, 01:37 AM   #2
Any hole is my goal!
BWAL's Avatar
2021 Mustang V12
Quad Turbo with nawz
Location: modified88dreamer likes penis in and around his mouth
what is water wetter?
1989 LX 5.0
1990 LX 5.0
1993 LX 2.3 notch
1992 LX 5.0
1997 Cobra
Buy one get one free. PM me
i founded the founder of the cobra club
Old June 18th, 2007, 02:04 AM   #3
NottyBoy93's Avatar
I have heard good about coolant additives, but have never personally used them. What I have heard has been positive though.
Money might not buy happiness, but it buys speed and quality
Old June 18th, 2007, 02:22 AM   #4
neverfastenough1's Avatar
Never used it, but it is highly recommended in the Mustang Performance Handbook (paid endorsement??). Says it does exactly what it is supposed to do. Improves the heat transfer between the block and the water.
Old June 18th, 2007, 02:26 AM   #5
I used it before. Didnt notice a difference.
Old June 18th, 2007, 02:37 AM   #6
Did you have an overheating problem??
Old June 18th, 2007, 09:41 AM   #7
SALIV8's Avatar
i used the purple ice, its not redline i forgot the brand, but it cost me like 20bux for a small bottle and did not notice any difference
Old June 18th, 2007, 05:13 PM   #8
Zippee is my step sister.
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
I used Water Wetter in my big block Ranger and it didn't run any cooler. It ran hotter if anything. BUT, like always every vehicle is different.
Thanks to: Trick Flow, Team Z Motorsports, Total Engine Airflow and Furo Racecraft
Old June 18th, 2007, 06:26 PM   #9
JBIGBOOTSY's Avatar
1990 LX hatch
watter wetter is designed to transfer some of your money to a company that makes pretty good lubes.
Old June 18th, 2007, 06:57 PM   #10
NottyBoy93's Avatar
Purple Ice is a Royal Purple product. Like I stated, I have no real experience of my own with additives, I do know that ethylene Glycol (anti-freeze) has limitations, it also has a tendency to sludge and turn conditions in your cooling system alkaline. The impression I get is that the additives are not always a function of more efficient cooling, I hate to break the news but efficient cooling is much more a factor of surface area then "slicker" water. Additives if anything will only help improve system chemistry, which can be beneficial. I live in Texas, and right now it is about 102 degrees with the humidity, and plain ole anti-freeze and water is all I have ever ran. I am old school like that. That and a little time spent in chemistry dictates that water is an efficient cooling medium with a somewhat lower boiling point, however if you are running hot enough to boil all of the water out of your car you have more problems than "water wetter" will fix.
[/rant off]
Old June 18th, 2007, 10:00 PM   #11
I guess take redline off the shopping list is the general consensus!!! Its only recommended for cars with minor heating problems anyways, and like stated before if you are really overheating, you got more problems than it will help. Probably was just a paid endorsement.
Old June 18th, 2007, 10:13 PM   #12
1993 notch
water wetter purple ice and all that stuff is supposed to reduce the surface tention of water there by reducing friction and heat also making the water flow smoother giving it less resistance but so does regular coolant and soap
fore those of you who dont know what surface tention is there 2 ways to explain it
1 fill a glass with water to the brim so the surface of the water is above the glass like a bubble than add soap the water will go flat and the excess will flow out of the cup
2 soap makes water wetter if you run water over your hands it will beed and run rite off when you add soap it reduses the surface tention of the water there by helping to clean.
hope this helps
Old June 18th, 2007, 10:53 PM   #13
I used it in my supercoupe cause my buddy swore by the stuff. But that car never ran hot anyway so I cant say what benefits it gave, if any.
Old June 19th, 2007, 12:15 AM   #14
nolife's Avatar
91GT, 88GT, 02GT
Plain old water has a higher specific heat capacity then water mixed with antifreeze. Meaning water can remove heat more efficiently from something then a water/antifreeze mix. If you dropped a chunk of hot metal into a bucket of plain water, it would cool down quicker then if you threw the same piece of hot metal into a bucket of 50/50 water antifreeze mix. No one should run plain old water though because you may have boil over easier when you shut off your car, it freezes at 32F, and there is no corrosion protection. The water wetter products are an attempt to get the benefit of using a mainly water coolant for the increased cooling capacity, provide some corrosion protection, and reduce the surface tension (gives a much smaller laminar boundary layer) of the water or a 50/50 water/antifreeze mix to give you even better cooling then water alone. The wetter products do not provide any significant freeze or boil protection. The thinking is, since you get better heat transfer then 50/50 and water alone, you will keep critical parts of the engine cooler which allows you to tune a little more aggressively. It does not perform magic either, you still need a properly working radiator and fan. I make no claims of the effectiveness or usefulness. Just providing the theory. I guess the wetter products performance gains are similar to using a water injection or water/methanol injection kit, it is not really the wetter or the injection kit that provides the additional power, it is the aggressive tuning or additional boost you can use while using them.
*Looking for a decent 90-92 Titanium hatch pull cover and retaining clips*
Old June 19th, 2007, 12:27 AM   #15
NottyBoy93's Avatar
I don't think anyone was advocating the use of just water, rather the benefit of additional chemicals in addition to anti-freeze/water.
Old June 19th, 2007, 12:38 AM   #16
nolife's Avatar
91GT, 88GT, 02GT
Neither was I. I was giving a comparison of each. Water wetter is supposed to be used in plain water, not in a water/antifreeze mix. Using it in a mix is just about useless.
Threads Similar to: does anyone use water wetter from red line
Redline Water Wetter Bossman351 Parts 18 September 18th, 2009 02:36 PM
off the line 02stang02 V6 Mustangs 26 August 24th, 2007 12:51 AM
Line for a 95 GT GTsetGO 94-95 1 June 25th, 2007 02:51 PM
Water Line From Radiator MustangMo V6 Mustangs 2 June 3rd, 2007 02:11 AM
Forum is powered by vBulletin ©2000 - 2010, Jelsoft Ent. Ltd. & SEO by vBSEO 3.3.2 ©2009, Crawlability, Inc.
