1989 GT Hatch
Can't get my fuel pump out
Trying to remove my stock fuel pump and replace it with a 255lph BBK (walbro) hv fuel pump.
I don't know how to remove this style clip (green arrow) to get the line off and also, you can see my pump is loose, but how do I get it out? It seems like there is no way it will come out of the hole. I've tried but I don't want to break something, am I missing something? I might need help with putting the Walbro in if it's a little different so if you can help me there also check back when I have a problem. Thanks. 1989 Mustang GT 5.0HO T5 Pic.....................
IIRC i just pushed in the clips there at the end (you can see them in the photo). if that doesn't work you should be able to get a screwdriver head into the slots on the side to unclip it. the fuel pump assembly will come out, you just need to angle it out of there. wait until you put it back in...that's the "fun" part :wink
Big timin' in a small town
There should be a triangular part on one side of the line stick a flat head screwdriver under it and pry the clip out far enough to grab onto t with your fingers to pull it the rest of the way out.
Putting the lines back on is much easyer than taking them off you just put the clip all the way on and then push the lines back in until they snap into place. It will come out of the hole you just have to take of the line and keep trying different angles to get it out
1989 GT Hatch
done, it came with new clips.
Threads Similar to: Can't get my fuel pump out
| fuel pump | Baldy | General Tech | 2 | October 3rd, 2007 10:45 AM |
| Fuel pump | Mustang RacR94 | V6 Mustangs | 16 | September 27th, 2007 06:36 PM |
| Fuel Pump? | lugthug713 | 94-95 | 1 | July 31st, 2007 11:38 AM |
| fuel pump fuel pressure stuff | JBIGBOOTSY | 5.0 Mustangs | 2 | April 26th, 2007 03:31 PM |
