1995 Mustang GT
Supercharged or 351
I have a choice between a 87 fox with a 351 windsor and a 91 notch with a new cobra motor, e303 cam, 24lb injectors, ect and a powerdyne supercharger. Now im wondering which would make more power and have more potential?
1991 Ford Mustang GT
Your not really giving enough info, to know which one is making more power. Whats done to the 351 ? The 351 has a higher power potential, but if its just some random stock 351 , then im guessing the supercharged 302 is makin more power as of now.
That being said, powerdyne is one of the worst superchargers on the market, there internally belt driven. Which makes them run cooler then other superchargers ( thats a good thing ) the negative is they cant spin vary high and the belts break. The E303 cam is old out dated tech,( there from the early 90s )there are much better cams out there. So dont let the fact, that the car has an E cam, be a selling point.
#3 | |
1995 Mustang GT
No, im not saying to stay away from it because of the supercharger, im just saying dont let that be a factor in paying more money for that car. That supercharger can be pulled off and sold for $1000-1200 on ebay.
1995 Mustang GT
So it will make good power still but might have a problem breaking a belt correct? and what about spraying a supercharged mustang?
A positive is the notch is worth more then the 87.
The 1991 has mass air and bigger wheel wells and can take a bigger wheel, it has air bags, nicer smaller head rest and shoulder belts in the back seat for safty. So in my opinion, with out seeing either car id go for the 91 notch.
#7 | |
1995 Mustang GT
I dont know any thing about spraying the juice.... thats some thing , ill leave to some one else to answer. If your not hard on it, by over spining the charger, it might last a long time. I dont think the belts cost that much.
Post pictures of each.. inside and out. How are the bodys ? Dont buy a rust, or bondo bucket, or any thing with a salvage title
#10 | |
1995 Mustang GT
1991 MUSTANG, NOTCH (SUPERCHARGED) Heres another i just found: http://milwaukee.craigslist.org/cto/2932309703.html |
The wing is gay, and the hood looks like it should be on a 1983 mustang.
If you get it. Take the wing off, and run it with out one.. change the hood to either stock, or a cowl. Find out if its an original v8 car or if it was a 4 cylinder converted over to a v8
1995 Mustang GT
Your talking about the 91? yeah thats what i thought. ive never seen a fox with that wing. what about the other the 87 with the vortec?
There both nice. I didnt see where the 87 had a 351.
The 87 has a better supercharger, the intake is worth more then whats on the 1991. The 87 seems like it has better parts. Both cars state that they have gt40 cylinder heads. Ill post a picture of them so you know if the car really hs them or not, cuz some people lie. If you look on the right you will see 3 bars, if they dont have that marking then there not gt40. If you see 4 bars then there gt40p heads which are good to.
One thing i do find odd about the 87. The add states he has 50 lb injectors (which is over kill for that combo) but that not whats odd, he has a F.M.U on the passenger strut tower.
Any ways its bed time, ill check this thread tomorrow The only way i can see how that set up would work is if he has the fuel pressure turned way down and is using the fmu to give more fuel pressure under boost....... other wise id think he would flood the engine at idle. But thats just a guess
![]() DART 331ci stroker, AFR 185 heads, Trick Flow R intake, Accufab 70mm tb, 75mm pro m Maf, 30lb injectors, jba headers, 2 1/2" x pipe flowmaster super 10 mufflers, 255 fuel pump, 3:27 gears Last edited by ryanw; April 12th, 2012 at 12:04 PM. |
1995 Mustang GT
Okay thanks for the tip on the gt 40 heads. And thats not bad though is it? as long as its tuned correctly and what is a F.M.U?
1991 gt cobra clone
17.48@77.8
![]() iTrader: 2 reviews
fmu takes small injectors and makes them flow more underboost...a better way to fix it is get correct injectors and maf.
hope that helps]
First car: 306, TFS th P&P, Tfs stg 2 cam, extrude cobra intake or ported systemax 2. Spintechs FTMFW |
1993 Mustang GT
if i had the choice when buying my fox, i would have gone with a notch personally.worth more, lighter weight, and nice looking.
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong. BBK CAI Dual Flowmasters Hurst Shortshifter Smog Delete Gatorback pulleys. FULL LED Tailights NEWEST ADDITION: Eaton M90 supercharger kit |
1995 Mustang GT
Well my buddy has a 1988 Mustang Gt with headers, flowmaster exhaust, mild cam, intake, and 3.73 gears. He offered to sell it to me for 2700 bucks. The car has some rust but not a lot and 123,000 miles on it. Its very well maintained because his step father loves mustangs and has a fully restored 69 fastback and he knows what hes doing. So my question is would that car be able to take a 150 wet shot? very well maintained no joke!
1991 gt cobra clone
17.48@77.8
yes my dads buddys car is a 89 lx 302 svo heads,small cam,and cobra intake,200 shot, slicks,and 373s all stock suspension not even rear control arms runs 10s all day.
Threads Similar to: Supercharged or 351
| 3.8 supercharged | Mcloven89 | V6 Mustangs | 4 | February 19th, 2011 01:32 AM |
| Anyone here have a supercharged c6? | 06Black5spdGT | All Other Vehicles | 0 | November 11th, 2008 06:42 PM |
| Supercharged v6 | FireryDriver | 2005 - 2010 | 91 | March 19th, 2008 02:24 PM |
