30lb injectors/Walbro 255/pro m MAF combo
Old April 13th, 2012, 09:30 AM   #1
ReefBlue1994's Avatar
1993 Mustang GT
ReefBlue1994 is on a distinguished road
Scored my injectors for 80 bucks used, got my Walbro for 60 bucks used,and bought a pro m brand new tuned for 30 lb for the hell of it
This will go with my 5 psi m90 blower combo...thoughts....comments?
Sent from my Autoguide iPhone app
1993 Mustang GT (Reef Blue on platinum) 105k Miles, still strong.
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
NEWEST ADDITION: Eaton M90 supercharger kit
Old April 13th, 2012, 10:34 AM   #2
ryanw's Avatar
1991 Ford Mustang GT
ryanw is just really niceryanw is just really niceryanw is just really niceryanw is just really niceryanw is just really nice
Good choice..... i, my self would have bought the fuel pump new....
Trick Flow R intake,
jba headers, 2 1/2" x pipe
flowmaster super 10 mufflers,
255 fuel pump,
3:27 gears
Old April 13th, 2012, 11:47 AM   #3
1993 Mustang GT
So was that tuned pro m mass air (30 lb)worth it?because I've been doing research seeing that "tuned" meters are bs,and that the real tuning is in the computer..and the fuel pump is almost new.let me see if I can find the ad.
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old April 13th, 2012, 11:47 AM   #4
1993 Mustang GT
Originally Posted by cgarray17 View Post
Like it says got a slightly used Walbro 255 pump in good working condition will all parts. Will take $70 shipped anywhere in US.
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old April 13th, 2012, 03:17 PM   #5
ryanw's Avatar
If your getting the car dyno tuned, then maybe you didnt need the calibrated maff, but if your going to run it just like it is then you need it.
255 fuel pump,
3:27 gears
Old April 13th, 2012, 04:19 PM   #6
1993 Mustang GT
Yeah I prefer not to tune it because of the cost haha
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old April 13th, 2012, 04:30 PM   #7
ryanw's Avatar
You should tune it though, tuning it will prevent things like, running rich at idle and lean at WOT.
255 fuel pump,
3:27 gears
Old April 13th, 2012, 05:27 PM   #8
1993 Mustang GT
Yeah true,isnt it several hundred dollars usually?
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old April 13th, 2012, 05:58 PM   #9
ryanw's Avatar
Yes, but you should have planed on that before you did this swap.
The first tune cost the most because your buying a chip from them. Every tune after that is cheaper cuz you already have the chip.
Most people spend alot on a kit like your, so since you bought it so cheap, take the savings and get it tuned
255 fuel pump,
3:27 gears
Old April 13th, 2012, 07:09 PM   #10
FastStang91Lx's Avatar
1991 Mustang LX 5.0
FastStang91Lx is just really niceFastStang91Lx is just really niceFastStang91Lx is just really niceFastStang91Lx is just really niceFastStang91Lx is just really nice
Hope you prefer half ass results then too.... And hopefully you don't repeatedly blow it up.
FastStang's Ongoing projects thread Click here!
Old April 13th, 2012, 07:31 PM   #11
1993 Mustang GT
Hahah! I have the money to tune it I was just wondering how Much a difference it makes?
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old April 13th, 2012, 08:32 PM   #12
ryanw's Avatar
Lets put it this way...... lets say that you had installed some gt40 cylinder head and intake, (instead of the supercharger ) and then you asked us if a tune is worth the money..... most of us would say you dont really need a tune.
But in your case with a home made supercharger, and bigger then stock injectors , which again, you may run rich at idle but run lean under boost.... it could really mess your shit up. Im not saying you will, but the cost of a tune is cheaper then a new engine. Just my 2 cents
255 fuel pump,
3:27 gears
Old April 13th, 2012, 09:47 PM   #13
1993 Mustang GT
Makes damn good sense!now are you guys talking dyno tune or like buying a bama tune?
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old April 13th, 2012, 09:55 PM   #14
ryanw's Avatar
A dyno tune
255 fuel pump,
3:27 gears
Old April 13th, 2012, 10:00 PM   #15
AdirondackFox08's Avatar
1990 Mustang GT
AdirondackFox08 is on a distinguished road
Dyno tune, I would not mess around with the bama tunes. They can't see what your a/f ratios are, they might get you somewhere in the ball park, better off spending your money on the dyno tune imo.
Old April 13th, 2012, 10:44 PM   #16
1991 Mustang LX 5.0
Dyno
Old April 13th, 2012, 10:51 PM   #17
1993 Mustang GT
Okay did you guys see my post on the m90 install thread,I found my leak...the front left intake bolt leaks air.found the problem.
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Old April 13th, 2012, 10:57 PM   #18
ryanw's Avatar
Yep...we saw it, thanks for updating us twice.
255 fuel pump,
3:27 gears
Old April 13th, 2012, 11:03 PM   #19
1991 Mustang LX 5.0
lol
Old April 13th, 2012, 11:05 PM   #20
1993 Mustang GT
Hopefully that's not why he sold it...I hope the adapter isn't warped.only reason I asked is because no one said anything!
BBK CAI
Dual Flowmasters
Hurst Shortshifter
Smog Delete
Gatorback pulleys.
FULL LED Tailights
Threads Similar to: 30lb injectors/Walbro 255/pro m MAF combo
30lb injectors enough? OutKast09 99-04 5 June 4th, 2010 05:34 AM
30lb injectors M.P. Cobra Fan 4V / SVT 4 May 7th, 2010 07:51 PM
