Discussing motor mounts in the 5.0 Mustangs Forum. how do u no when the motor mounts are gone,, in my 89 gt whenever ...
Old June 20th, 2006, 01:25 PM   #1
motor mounts
in my 89 gt whenever i pull of i have to kinda rev it up highier than usual so that it wont vibrate and i can feel the car vibrate whenever it is in low gear, at around 1200 rpm in any gear
Old June 20th, 2006, 03:54 PM   #2
Pop the hood, set the e-brake and put the car in gear. Give it a bit of gas (not enough to spin the tires, just enough to put a little torque on the motor) Do this in 1st and reverse. If the motor raises up on either side that mount would be bad. It will only move a bit if theyre good but will lift if one is broken.
Old June 20th, 2006, 04:32 PM   #3
exactly. but have someone stand in front of the car and watch the motor to see wich one(s) are giving. kinda hard to see when your in the car...
Old June 20th, 2006, 10:16 PM   #4
they look like this
Old June 20th, 2006, 11:13 PM   #5
Replace them. Those stress cracks are where the rubber will pull apart.
Old June 21st, 2006, 11:18 PM   #6
done deal went with some energysus. poly ones, love them. after putting them in i could feel a skip in my car, and led me to find some spark plug problems.
Old June 22nd, 2006, 02:02 PM   #7
Good deal man! Those polys are good quality parts and will last a long time.
Old July 22nd, 2006, 11:43 PM   #8
how do u replace them, i read that u have to disconnect the trans from the engine is that true, well what do u do
Old July 23rd, 2006, 12:26 AM   #9
No you don't have to remove the trans. to replace them.
Loosen them some and Jack the enigne up and then remove and replace the mounts.
I loosen the nut first then jack up. Once up enough then I remove the 2 screws on the ends and slide it out.
http://img.photobucket.com/albums/v6...ng8719/Sig.jpg
Eibach lowering springs,Intake ported to Max,Electric cooling fan,120Amp Alt.,FlowMasters,Jacobs FC1000 Ignition system with coil,King Cobra Clutch,APC Racing Seats
Threads Similar to: motor mounts
Motor Mounts ?? Dallas01GT 99-04 1 August 2nd, 2007 09:22 PM
Motor mounts Pony_with_an_attitude 5.0 Mustangs 3 July 25th, 2007 10:52 PM
motor mounts the real shocker 99-04 0 May 21st, 2007 10:29 PM
motor mounts the real shocker 99-04 0 May 21st, 2007 10:24 PM
motor mounts cali 5.0 5.0 Mustangs 1 September 11th, 2006 01:42 PM
