Discussing t5 tranny grinding gears in the 5.0 Mustangs Forum. Hey I have a 5litre 88 LX was auto, has been converted to manual with ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
t5 tranny grinding gears |
Sounds like you got the answer to the first question. Do you know if they put ATF in the tranny. Could be gear oil that takes a while to warm up. Supposed to be ATF.
2007 Explorer Sport Trac, 292 HP, Stock 2002 Mustang GT |
1990 LX hatch
It's prolly not the throw out bearing, If the bearing was bad it would make noise when pushed in or out. It sounds like your clutch cable is out of adjustment. That is your clutch fork rattling, it rattles because there is not sufficent tension on the cable, also causing possible shifting problems.
lightly push the clutch with your foot, reach under the quadrent and try to hold the quadrent in place with your hand, then put your foot under the clutch pedal and lift it twards you, tou should hear a good click.
Originally Posted by HELLRAZR94 what up pussy lets stop talking shit i would love for your pussy ass to come to cali so that i can show you what im about, when you get here let me know and i will come to you fag
I had a mechanic tell me the adjustment probably isnt the problem though, fuck its annoying i want it fixed lol... not to sure..
If the noise goes away when you push the clutch it is likely the input bearing, but I agree with Bootsy, it could be your fork rattling and I would try to adjust it before I tore it apart to replace bearings. And if thats the case that could solve the other problem also. Also it would be a grinding sound for a bearing I would think.
Threads Similar to: t5 tranny grinding gears
| What gears and tranny do i have?? | 06GTMustang89 | 2005+ | 6 | October 13th, 2007 01:50 PM |
| gear grinding | Blk01ponyGT | 99-04 | 22 | September 19th, 2007 05:02 PM |
| Grinding after the track | weems | 99-04 | 58 | July 13th, 2007 07:37 AM |
| grinding noises? | blue03mach1 | 94-95 | 4 | July 3rd, 2007 06:57 PM |
| tranny grinding | terribleonexx88 | 5.0 Mustangs | 12 | October 18th, 2006 11:13 PM |
