Broken Key Cylinder removal - Key will not turn, Ideas?
I have an '89 gt, built from the groung up. Only thing I did not replace was the key cylinder.
So it seem that the last tumbler in my key cylinder failed - I cannot insert the key all the way to turn to the run position. Anyone know how to remove it without being in the run position? |
Problem is the key buzzer has broken off and is stuck in the back of the cylinder! Not letting the key go all the way in! Even though it may seem to be its not! You need to remove that with a pick of some sort! Dig it out! Trust me! Im a locksmith and have come accross this many of times!
Mark |
Thanks alot! That makes total sense. I will try to dig the piece out.
Thanks SLRMARK, that is exactly what the problem was. I dug out the plastic laying on the bottom inside tumbler, hoped I got it all, and the key turned. Will this be an on-going problem? Should I change the key cylinder?
You can but the problem is not the cylinder itself its the plastic (grey) connector on the cylinder just remove it . You can unplug it if you take the column housing off and unplug the wire and pull the plastic off the cylinder. Then you will have no problems with that happening again!
Mark |
All that connector is, is for the key buzzer will not harm anything!
Mark |
Key cylinder from Advanced Auto - $13.74. What a deal! I will replace it for piece of mind. Thanks again.
Threads Similar to: Broken Key Cylinder removal - Key will not turn, Ideas?
| Cylinder heads removal help... | 99v6stang | V6 Mustangs | 12 | July 27th, 2007 12:05 AM |
| broken tranny | ByPopularDemand | V6 Mustangs | 16 | June 27th, 2007 06:40 PM |
| Car Broken into | GreenFaleen | V6 Mustangs | 35 | January 15th, 2007 03:28 PM |
| Car Got Broken Into. Help! | White2000GT | 99-04 | 9 | September 6th, 2006 04:44 PM |
| it's broken...... | Twist 2 Go | The Clubhouse | 15 | October 17th, 2005 01:02 AM |
