Discussing engine reved up and kept reving in the 5.0 Mustangs Forum. whats up guys and gals im a newbie on this forum and i had a ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
engine reved up and kept reving |
1990 LX hatch
big vacum leak? Did the throttle return while the engine was revving?
no the throttle did not return? i started it after i pulled to side and it just reved up.
89 GT
Stupid question, did you check to see if the gas pedal got stuck on the floormat?
Parts needed: TwEECer, if anyone has one for cheap. 70mm TB Full length headers and matching h-pipe For sale: Ford Racing E-303 cam brand new BBK 65mm TB, brand new BBK equal length shortys brand new BBK off road x-pipe for shortys used |
#5 | |
1990 LX hatch
no it didnt get stuck on the floor mat..........
You can't pull the pedal up by hand? If not, disconnect it from the throttle body and see if you can pull it up and push it down by hand. If you can than you need to clean your throttle body and/or check your spring. If you can't then you might need a new cable.
2007 Explorer Sport Trac, 292 HP, Stock 2002 Mustang GT |
#8 | |
1989 LX Coupe
Buy some throttle body cleaner and WD-40...spray the butterfly valve inside it.
This may be a simple fix...if that doesn't correct it, you have some deeper digging to do.
![]() 7.87 @ 93 mph
This Hunt Chev guy keeps bringing up really old posts, somebody stop him
89 LX 515 hp 497 ftlbs 88 GT 11.4 @ 118
1987 Mustang GT
my stock throttle body got kinda sticky in the end and the carb clean and wd-40 worked great for me
Threads Similar to: engine reved up and kept reving
| 5.0 Over reving on startup | cptkng79 | 5.0 Mustangs | 1 | June 21st, 2007 08:59 PM |
| 1990 GT NO Engine Will 96 4.6 licolin town car engine FIT?? | zygo4406 | 5.0 Mustangs | 10 | June 4th, 2007 05:53 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 05:09 PM |
| automatic shifting and reving ? | Redline | V6 Mustangs | 36 | February 15th, 2007 09:46 PM |
| My car is starting to make a high pitched noise while reving | Compy386 | V6 Mustangs | 8 | January 27th, 2007 04:19 PM |
