heads
Old June 21st, 2007, 11:07 PM   #1
GT 5.0 is on a distinguished road
heads
When looking for new heads which are the best to un for everyday driving but also enough power to smoke people when u got to
Old June 21st, 2007, 11:10 PM   #2
bwb3 is on a distinguished road
Trick flow twisted wedge heads, edelbrock performer or victor jr. heads, or AFR 165 or 185's. those are the best
i have fast cars....
Old June 22nd, 2007, 03:02 PM   #3
tording92lxnotch is on a distinguished road
Keep in mind that with the AFR 185's you will probably need to notch the pistons if they are stock to get the proper Piston to valve clearance you need. With the 165's you should be fine. For the money I don't know that it gets much better than the TFS TW heads.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old June 22nd, 2007, 11:00 PM   #4
neverfastenough1's Avatar
Yeah the ones they said, but stick with the 165's if you go AFR. unless you are stroking or supercharging then look at the 185's. I also believe the 185's are made for the 351 which means you would need reducers for the bolt holes, but they are good for high revving.
Old June 23rd, 2007, 02:20 PM   #5
invisa stang's Avatar
1992 mustang lx notch
invisa stang is on a distinguished road
Send a message via AIM to invisa stang
peferably i would go with the edelbrock victor jr heads manly because edelbrock was rated #1 for there heads
[rides
1987 ford F-350 XLT Lariat 7.3L idi diesel
projects
1979 ford F-350 custom (soon to get 7.3Lidi diesel)
1992 ford mustang notch (just shell soon to get engine and drive train hopefully)
Old June 23rd, 2007, 10:46 PM   #6
BLK90GTVERT's Avatar
1990 Mustang GT
BLK90GTVERT is on a distinguished road
im sorry but i thought he said.........everyday driving. but i guess if you have the $800-$1500, aluminum heads would be the way to go. be ready to lose alot of mpg. but to save you about 5 to six hundred bucks cast iron gt-40s with a hand port do just fine. im mostly stock and running twelves on those heads. just a suggestion.
Threads Similar to: heads
GT 40 X Heads. Need Help Deciding On These Heads, Or AFR`s BillR1970 Parts 8 May 12th, 2009 09:01 PM
GT40 heads vs GTP heads 99TurboV6Stang 5.0 Mustangs 9 September 18th, 2007 09:34 PM
RHS heads , are they good cylinder heads? hitorx 5.0 Mustangs 25 May 12th, 2007 09:55 PM
289 Heads ezra27 General Tech 0 December 30th, 2006 11:09 PM
Boss 302 Heads Same As Cleveland Heads? ken5_0 Classic Mustangs 8 September 25th, 2006 03:18 PM
