Trick Flow Track heat valve springs?
Old June 23rd, 2007, 01:08 AM   #1
What does it take to get these on a pair of iron GT40 heads??? I hear there is some cutting involved, and i would also have to get the Trick Flow locks and retainers as well...
Is it true that you have to modify the head some to get them on there? Typical cost of that if anybody knows?
For what it's worth, GT40 heads, FMS B303 cam, and Crane 1.7 RR's, and i want plenty spring to hold.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old June 23rd, 2007, 05:02 AM   #2
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
If the heads don't have a spring pocket big enough to accept them you will need to have the spring pockets cut. Get valve springs to match your cam. The B cam doesn't need much for a spring.
Old June 23rd, 2007, 02:31 PM   #3
So are the stock GT40 springs alright? That is what is on the heads and they are new as the heads are fresh out of the shop with a valve job, and all that jive.
I think with the 1.7s i will have like a .510 or .514 lift...does that sound right Darrell?
[SIGPIC][/SIGPIC]
Threads Similar to: Trick Flow Track heat valve springs?
Trick Flow Top end kit. Timm10221 5.0 Mustangs 23 October 17th, 2007 03:36 PM
Trick Flow street and track heat shurb125 5.0 Mustangs 3 June 11th, 2007 11:43 PM
Trick Flow Track Heat Top End Kit shurb125 5.0 Mustangs 4 April 20th, 2007 12:31 AM
Trick Flow Track Heat Kit Erron89 5.0 Mustangs 6 February 8th, 2007 06:08 PM
Trick Flow Street Heat stang94 5.0 Mustangs 25 December 11th, 2006 12:34 PM
