90 rear disc brake conversion
Old June 23rd, 2007, 01:05 PM   #1
7-up man is on a distinguished road
I want to do a rear disc conversion to my 1990 LX. Its already been converted to a 5 lug by the previous owner.
What components do I need to buy? any suggestions on vendors? and who sells a complete kit with rotors, calipers, pads, etc?
I am assuming I need rotors, calipers, brackets, pads, backing plates and brake lines.
should be a very simple conversion correct?
Thanks
Old June 23rd, 2007, 05:17 PM   #2
fogged306's Avatar
89 GT
I had an SSBC full 5 lug conversion with rear disc brakes at one point. I never put it on my car because I ended up selling it but I worked on a few project cars alongside the company and those brake kits were unbelieveable. My whole shop was paid for our services with kits for our cars, and everybody else puit their kits on their car and they were rediculous. you actually could stop so quickly that you had to be careful of cars behind you because you could cause them to rearend you in a hurry. The only problem that was noted was they were pretty bad in the rain but nobody really drove cars like that in bad weather anyway.
www.stainlesssteelbrakes.com/
Old June 23rd, 2007, 05:20 PM   #3
fogged306's Avatar
89 GT
Ok I cant get that stupid link to work but that is the website, just type it into your browser.
Old June 23rd, 2007, 11:05 PM   #4
neverfastenough1's Avatar
You know if you google disk brake conversion on a fox body mustang, you will get a lot of info on how to do it with sn95 parts and Mark VIII parts. Summit also has the kits for SSBC and Wildwood, and I believe FRPP has kits as well.
http://store.summitracing.com/egnsea...115+4294901314
Old June 24th, 2007, 12:10 AM   #5
93 GT Hatch
12.68@112.57
superman5.0 is on a distinguished road
Send a message via AIM to superman5.0
northracecars.com has exactly what you need for just under 800 bucks. im lookin to do it pretty soon too.
Old June 24th, 2007, 07:22 AM   #6
the kit from SSBC looks like exactly what I need, except the rotors in that kit are still a 4 lug set up??
I guess you can ask them to just swap those for 5 lug rotors with the kit?
Old June 24th, 2007, 11:00 PM   #7
86er's Avatar
I went to a junk yard, got all the brackets and plates off of a 91 lincoln mark 7
got some remaned calipes from work, and rotors from the lincoln and Its worked just fine so far
Just a truck
Old July 1st, 2007, 12:23 AM   #8
Mountainpony76 is on a distinguished road
You have a couple of options. You can use parts from an sn95 or order a conversion kit. either way you should make sure to get an adjustable proportioning valve.
1991 GT wild strawberry red. 331 sb. AOD with TCI master race kit and TCI ss converter. B n M shift kit. 4:10 motive gear set in the rear. 245/50 16 wrapped around the factory pony wheels.
Old July 1st, 2007, 02:56 PM   #9
fogged306's Avatar
89 GT
Yea they have a 5 lug kit, thats what mine was... it came with moser axles and all
Threads Similar to: 90 rear disc brake conversion
2002 Mustang GT rear disc brake Question lucidsoul5 General Tech 8 September 2nd, 2010 11:29 PM
Disc Brake Conversion wonders_of_a_V8 Classic Mustangs 6 January 20th, 2009 09:16 AM
Disc Brake Conversion gotboost562 5.0 Mustangs 8 November 10th, 2007 05:38 PM
Help Finding Disc Brake Conversion Kits 66gtmustang Classic Mustangs 15 November 13th, 2006 07:20 PM
Got another disc brake problem. lucidsoul5 General Tech 0 July 24th, 2006 10:46 PM
