fuel pump
Old June 24th, 2007, 01:06 PM   #1
95wip is on a distinguished road
Send a message via AIM to 95wip
fuel pump
what is a good fuel pump? model, style, brand? and LPH? i plan on running a 100 or 125 shot in the near future! and i am ordering parts and have the car in peices so i thought this would be a good time...
95' GT is being reconstructed!
Old June 24th, 2007, 01:17 PM   #2
jam77's Avatar
1987 Mustang GT
jam77 is on a distinguished road
fuel pump
bbk 255lph
Old June 24th, 2007, 08:13 PM   #3
seems like over killl i was thinking 155lph or 190lph
Old June 24th, 2007, 08:40 PM   #4
TENGRAM is on a distinguished road
no such thing as overkill, as long as the return line can flow well enough to return all excess fuel...and the stock return line is fine for a 255lph. also, the BBK and most other brands are just repackaged Walbro pumps so don't get hung up on brand name just buy the cheapest one you can find. my2cents
89 GT t5 3.73
www.my5oh.com/
Old June 24th, 2007, 09:14 PM   #5
Walbro 255 lph...It's like $100
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old June 25th, 2007, 05:23 AM   #6
neverfastenough1's Avatar
You got other plans than spray? Wet or dry? Stock lines are marginal at 190lph and 255 is useless with stock rails. If you go with the 255 I would get the lines too. Here's why. When you are sitting there idling or cruising around, you are sending what 200+lph back thru the stock lines. Sure they will flow it. Not quite well though. Ever here of friction. That is what is caused when you try to force a lot of fuel thru a little line. Friction causes heat. Heat not only heats up the fuel but also heats up the pump. Between the heat and the fact that the pressure rises when the 255 lph hits the regulator and tries to go back thru the stock lines you are over working the pump. If all you are going to do is spray (up to 150 shot), the 190 will be fine and the fuel lines will work as well as the rails. Its not that the rails won't support it but the fact that they won't flow enough to need a 255lph pump. If later on down the road you do something else that needs more fuel like a supercharger or turbo, you can go with a boost-a-pump or separate fuel pump. If you are going with a wet system you should run a separate fuel system for it anyways. Some guy named Lidio Iacobelli said that a 190 with 36 lb injectors will support 500 hp with stock fuel lines. There are gadgets to raise voltage to the pump when you are at the track and vice-versa there are gadgets to lower voltage when not at the track.
Old June 25th, 2007, 10:57 AM   #7
i think i am gunna do 190 because i am not doing lines or rails or any of that
Threads Similar to: fuel pump
fuel pump Baldy General Tech 2 October 3rd, 2007 10:45 AM
Fuel pump Mustang RacR94 V6 Mustangs 16 September 27th, 2007 06:36 PM
Fuel Pump? lugthug713 94-95 1 July 31st, 2007 11:38 AM
fuel pump fuel pressure stuff JBIGBOOTSY 5.0 Mustangs 2 April 26th, 2007 03:31 PM
