fan direction,,
Old June 25th, 2007, 12:33 PM   #1
Fastpitchdad's Avatar
Fastpitchdad is on a distinguished road
fan direction,,
i have my electric fan mounted on the engine side of the radiator.my question is should it be pulling air through the radiator or pushing it through it.My friend has his pushing and mines pulling.which way is correct..
Old June 25th, 2007, 12:34 PM   #2
86er's Avatar
86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold86er is a splendid one to behold
pullers always seem to work better.
Just a truck
Old June 25th, 2007, 01:49 PM   #3
neverfastenough1's Avatar
If its on the engine side you want it to pull the cool air from outside the car thru the radiator, not push the hot air from inside the eng compartment thru the radiator fighting the incoming air form the car moving forward. Like 86er said it will work better.
Old June 25th, 2007, 01:56 PM   #4
ok thanks,,,,,i'll leave it the way it is
Old June 25th, 2007, 01:58 PM   #5
Please say your friends isn't on the engine side of the rad. If so its on the wrong side.
Old June 25th, 2007, 02:09 PM   #6
yes it is,i'll change the direction of the flow tonight,his cars a 90 notch 351
Old June 25th, 2007, 02:20 PM   #7
usmcsawgunner's Avatar
1993 Mustang GT
13.2 @98.54
usmcsawgunner is on a distinguished road
Send a message via Yahoo to usmcsawgunner
mines on the engine side and does fine? how would you fit it on the outside of the radiator?
Old June 25th, 2007, 02:39 PM   #8
I have never seen a pusher on a fox. Pusher aren't recommended for primary cooling. They are usually used for secondary cooling. A pusher fan is about 20-30 percent less affective, and thats when it is mounted in the right place. When you put a fan in front of the rad it is actually impeding some air flow when it is not on. A fan behind the rad is not in the way of air flow going thru the rad. Your car when going down the road is automatically sucking air in the rad. If you have a pusher on the back of the rad pushing air forward, it is pushing against that air. Google pusher fan vs puller fan. The whole purpose of the rad is to cool the water. The coolest air is outside the car.
Old June 25th, 2007, 06:52 PM   #9
1993 Mustang GT
13.2 @98.54
so youre saying the fan is supposed to be in between the rad and the engine and it blows in accordance with wind flow? i think i just got mixed up...hapens a lot
Old June 26th, 2007, 03:50 AM   #10
Yep. Somehow that friend of his either bought the wrong fan or wired it backwards.
Threads Similar to: fan direction,,
which direction to go sonicblue Modular Mustangs 15 July 7th, 2007 03:11 PM
Cobra Symbol Direction??? Slowbra_12 96-98 2 June 7th, 2007 08:22 PM
need help figuring which direction to take thecloneranger Modular Mustangs 2 March 4th, 2007 01:30 PM
The New Direction of Ford need4steed 2005 - 2010 23 December 10th, 2006 09:42 PM
The Wrong Direction Horseshoeing Classic Mustangs 1 August 8th, 2006 01:31 PM
