engine bay clean up
Old June 22nd, 2006, 08:13 PM   #1
militarygt's Avatar
militarygt is on a distinguished road
engine bay clean up
i was wondering what i might be able to get rid of under the hood and free up some room and perhaps some power. also does anyone know how if i can get rid of the egr tube from the headers? thanks
Old June 22nd, 2006, 11:52 PM   #2
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
some options that come to mind are, delete egr/smog, a/c, battery relocation, washer relocation
...even fire and single cammin
1986 Ford F-150 5.0L 2WD
1994 Toyota Pickup 2.4L 4WD
1999 Ford Mustang 3.8L V6
2002 Jeep Grand Cherokee 4.0L 2WD
2008 GMC Sierra Denali 6.2L AWD
Old June 23rd, 2006, 12:20 AM   #3
militarygt's Avatar
ya i should have metioned that first. the battery is already in the trunk and the smog pump is gone. i plan on going with a manual steering rack in the near future.
Old June 23rd, 2006, 12:23 AM   #4
relocate the wiring behind the inner fenders. It's not that hard to do and really cleans up the underhood area.
88 Mustang Coupe
www.rickscarcare.net
Old June 23rd, 2006, 03:56 AM   #5
dcraig8 is on a distinguished road
get rid of your egr valve and tube. put a blockoff plate on your intake where your valve mounted and then cap off your header bung with a steel threaded cap and that will get rid of your tube.
Old June 23rd, 2006, 05:07 AM   #6
militarygt's Avatar
awesome thanks. i will do that this weekend. also will that set the check engine light off?
Old June 24th, 2006, 05:33 AM   #7
no, it wont set off your check engine light....let me know how it comes out
Old June 27th, 2006, 11:46 PM   #8
militarygt's Avatar
thats odd because when i unpluged the egr, the light came on almost instantly. i may just block it off but leave it plugged in. unless anyone has any better ideas?
Old June 28th, 2006, 05:32 AM   #9
get rid of your smog pump, if you havent already. disconnect your negative battery cable for 20 minutes and then reconnect it. that should take care of your check engine light
Threads Similar to: engine bay clean up
How do you clean your engine? JONJON 5.0 Mustangs 10 October 13th, 2007 02:16 AM
How do you clean your engine?? Timm10221 5.0 Mustangs 20 October 12th, 2007 10:36 AM
Clean Engine MnrlGry01gt Visual 6 April 16th, 2007 09:58 AM
64 1/2 Engine Clean Eman24 Classic Mustangs 1 March 24th, 2007 05:27 PM
Clean engine MnrlGry01gt Visual 1 September 2nd, 2006 04:23 AM
