3.73 gear install?
LinkBack (1) Thread Tools
Old June 25th, 2007, 06:28 PM   1 links from elsewhere to this Post. Click to view. #1
1994, mustang gt
N/A
izze01 is on a distinguished road
Send a message via AIM to izze01
3.73 gear install?
I just replaced my stock 2.73's with the ford 3.73's and I was wondering what the part looks like that fixes my speedometer. If anyone has pictures or knows how many teeth are on it please let me know. Thanks
Old June 25th, 2007, 06:33 PM   #2
HMUSN's Avatar
iTrader: 9 reviews
I believe you need an 18 tooth one.
http://www.fordracingparts.com/download/charts/129.pdf
Old June 25th, 2007, 10:25 PM   #3
TENGRAM is on a distinguished road
Re: 3.73 gear install?
what year is your mustang? 83-89 you need a 21 tooth...
89 GT t5 3.73
www.my5oh.com/
Old June 25th, 2007, 11:33 PM   #4
1994, mustang gt
N/A
I have a 94 mustang gt.
Old June 26th, 2007, 12:29 AM   #5
the 23 tooth will get you close enough. to get it perfect you would need to also change the tranny drive gear to a 7 tooth. i believe the drive gear would be located in the tail section of the tranny but you should find a diagram to be sure.
89 GT t5 3.73
www.my5oh.com/
Old June 26th, 2007, 08:13 AM   #6
1994, mustang gt
N/A
Thanks man. How close are we talking with just installing the the 23 tooth gear?
Old June 26th, 2007, 08:16 AM   #7
neverfastenough1's Avatar
It will be real close but off a couple mph and also the 23 tooth gear if you research it has a problem with stripping because the teeth are too small. They are only expected to last around 25,000 miles.
Old June 26th, 2007, 08:29 AM   #8
+1 the drive gear is located right where the speedometer cable goes into the tranny. If you are going to take it apart I would suggest going one better than the 7 tooth and get a 6 tooth.
http://www.mustang-tech.org/wiki/94-...eedometerGears
Old June 26th, 2007, 07:24 PM   #9
1994, mustang gt
N/A
I have 17 inch rims with 245/45's and stock teeth for 2.73 gears. Which tranny drive gear is usually in the tranny the yellow or the green. Should I get a 18 or 21 tooth driven gear to be the closest.
Old June 26th, 2007, 07:29 PM   #10
Big timin' in a small town
Drick's Avatar
2004 FX4 F150, 86 GT
23 tooth gears are junk they strip fast mine had one in it when I bought it and there wasnt a tooh left on it
FX4 Crew
Crew member #1
Don't take anything I say to heart, I don't try to come off as an asshole. It just happens
Old June 26th, 2007, 08:36 PM   #11
1994, mustang gt
N/A
so what is everyones idea of what i should do. I don't feel like taking apart the tranny I don't really have alot of time to do anything right now. Any suggestions.
Old June 26th, 2007, 09:35 PM   #12
i would just get the 23 tooth and see how it does. if it does strip after awhile then switch down to a 21 tooth.
89 GT t5 3.73
www.my5oh.com/
Old June 26th, 2007, 11:03 PM   #13
+1, i talked with the guy who did my gears and that is what he does on the side and knows his stuff...Get the 21 tooth gear, and no more teeth because they are thin and tend to chip and break.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
LinkBack to this Thread: http://www.moddedmustangs.com/forums/5-0-mustangs/26367-3-73-gear-install.html
Speedometer/Gears Question - BuckeyeStangs Message Forums This thread Refback March 16th, 2009 05:05 PM
Threads Similar to: 3.73 gear install?
3.73 gear install? Mustang01996 V6 Mustangs 4 September 3rd, 2007 04:04 AM
Gear install 04gt 99-04 7 June 17th, 2007 07:09 PM
Gear and t-lok install GreenFaleen V6 Mustangs 12 January 31st, 2007 12:03 AM
Gear Install acehogg69 2005 - 2010 7 January 28th, 2007 01:49 PM
I need to buy a 4.10 gear install kit. FireryDriver 2005 - 2010 10 December 28th, 2006 04:10 PM
