Help with problem
Old June 24th, 2006, 12:35 PM   #1
88notch is on a distinguished road
Help with problem
i was driving around yesterday and decided to do a high speed pull. i got it to around 140 and let off (pushed in the clutch and coasted. when i got home i noticed the engine was making a tapping sound so im am guessing that its lifter tap. does anyone know if this sounds pretty accurate and how do i fix it? thanks
Old June 24th, 2006, 06:04 PM   #2
frankenstein is on a distinguished road
could be alot of things. water pumps can make a tapping sound when the bearings are going out... an exhuast leak can fool you with a tapping sound. but if you can get ahold of a stethoscope (can buy one at auto parts store) and put the metal probe end on the valve covers and if you hear a definate ta, ta, ta, ta,.... ect. from within the valve covers then your question is answered. as for the fix... well you'd have to asses the damamge first and see whats doing the tapping
Old June 24th, 2006, 11:53 PM   #3
well i had a mechanic take a look at it today and he told me from the way it sounded that it was probably a bent rod (he said it sounded like piston slap). didnt think i could bend a rod on a stock motor that easily. now the question is what motor to go with? any opinions?
Old June 25th, 2006, 03:51 AM   #4
militarygt's Avatar
militarygt is on a distinguished road
well that all depends on your ability to build one and, or the money you have to spend. there are some affordable crate engines out there that have great power and a warranty. so it really is up to you.
Old June 26th, 2006, 12:25 PM   #5
IcantDo55 is on a distinguished road
140 on the street....luckey its only a bent rod.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old July 3rd, 2006, 08:34 PM   #6
well i did a little investigating and when i pulled the passanger rear wire the sound went away. can anyone tell me what this means (can it be fixed or do i need new motor?) so i make sure it doesnt happen again. this engine only has 87,000 miles on it.
Old July 3rd, 2006, 09:58 PM   #7
My Stallion is Bigger!
turp's Avatar
1989 Eddie Bauer Bronco
3 feet...
turp is on a distinguished road
Send a message via AIM to turp Send a message via MSN to turp Send a message via Yahoo to turp
Sounds to me like a perfect time for a stroker kit!
Old July 5th, 2006, 08:37 AM   #8
88_50 is on a distinguished road
I'm going out on a limb here without hearing it and say your mechanic is wrong. I've took plenty of Mustangs 140 and of above, and never ever bent a rod. I've shifted at 7k rpms with stock rods continuly. Stocks are by no means strong, but I can't imagine bending one on a 140 mph pass on the highway. Maybe a pushrod, but not a connecting rod. A lifter on the other hand could have easily failed.
If you have the funds for a stroker, by all means go for it. I'm a believer in them. But if its not, fix your 302 and enjoy it. A piston knock is a destict sound. If its just a light tap, then I would replace the lifters. This is a great time to replace your timing chain, cam, and lifters. While its a part, I would also have the heads freshened up and maybe even a good port match on the heads and intake.
Just my two cents...
Old July 5th, 2006, 07:43 PM   #9
is there any way to determine weather its something in the bottom end or topend without ripping the motor completely apart. i was hoping this engine would last me atleast a couple years, till i could purchase a new stroker. someone told me to place a screwdriver on the oilpan and feel if its tapping. if it is then its something in the bottom end and same with the valve cover for something in the topend? whats you thoughts?
Threads Similar to: Help with problem
umm have a weird problem? idle problem? blue03mach1 99-04 16 March 4th, 2008 01:03 PM
Has your car ever had a problem? JASonic The Clubhouse 17 September 19th, 2007 06:19 PM
big problem need help 96gtponyred 96-98 12 August 22nd, 2007 02:36 AM
RIM Problem and Help trueballerisme 2005 - 2010 70 August 21st, 2007 09:55 PM
TPS Problem? 88Horseman 5.0 Mustangs 11 November 14th, 2006 12:46 AM
