5.0 conversion
Old June 24th, 2006, 06:01 PM   #1
03stanger is on a distinguished road
5.0 conversion
im converting a 93 4cyl to a 5.0 carb'd.....the distributor was supposed to be out of a carb'd car but im not sure what wires i will need to hook up to it....i assume that i will have to find the stock plug for that distributor right?
Old June 26th, 2006, 04:00 PM   #2
fakesaleen's Avatar
1988 lx t-top
fakesaleen is on a distinguished road
if its a roller motor you will need the distributer from an 1985 mustang gt and the duraspark box (blue grommet) and the wiring from any 80's car witha a duraspark ignition also the canister style coil
http://i723.photobucket.com/albums/ww234/wendell1988/fakesaleen.jpg
Old June 27th, 2006, 05:53 PM   #3
what if its not a roller motor..just a plain just 40 over small block
Old June 29th, 2006, 02:26 PM   #4
fakesaleen's Avatar
1988 lx t-top
you can just grab one out of any early 80's ford 302 with a duraspark ignition probuly a grand marquis or crown vic, theres alot of those in the junk yard or just go to the autoparts store and buy the one specific to one of those cars, the diference is in the gear one is iron the other is brass.
Old June 29th, 2006, 07:38 PM   #5
thanks
Threads Similar to: 5.0 conversion
2v to 3v conversion??? droppedbass87 96-98 26 September 18th, 2010 01:08 AM
conversion Mustang RacR94 99-04 8 April 2nd, 2007 11:02 PM
2.3L to 5.0L conversion stan_doe 5.0 Mustangs 6 January 23rd, 2007 01:39 AM
99-04 V6 To GT Conversion ?'s ineedajob V6 Mustangs 7 November 9th, 2006 04:18 PM
After A 5 Lug Conversion... 347tt 5.0 Mustangs 7 September 28th, 2006 03:53 PM
