Nitrous question
Old June 29th, 2007, 08:33 PM   #1
89LX347's Avatar
89LX347 will become famous soon enough
Nitrous question
hey there people...i was just wondering how much my motor can handle im pretty sure it will be alright but i would just like some comfirmation...i have a 347 stroker CHP short block with probe forged pistons forged rods and cast steel crank shaft..TF top end 75mm TB and 30# injectors..i am in the process of installing a NOS wet kit with purge and everything and my question is what do you all(who have experience in this area) think the max HP shot of NOS should i use i was planning on only going up to 200 do you think thats alright?
Old June 29th, 2007, 08:49 PM   #2
JBIGBOOTSY's Avatar
1990 LX hatch
Depends on your current hp level, Prolly 200 max. dont exeed 500hp total engine hp with a production block.
Old June 29th, 2007, 08:57 PM   #3
89LX347's Avatar
i have about 450 on the motor maybe even more than that why do you say this?do you think i need a main support girdle?
I believe in art when it is not seen.
I believe in music when it is not audible.
I believe in God when He is silent.
Old June 29th, 2007, 09:09 PM   #4
mikebert is on a distinguished road
Send a message via AIM to mikebert Send a message via MSN to mikebert
What's making 450 horsepower in that engine?
Old June 29th, 2007, 09:43 PM   #5
89LX347's Avatar
the engine is making 450 hp...its very well built and im talking on the motor not RWHP
Old June 29th, 2007, 10:06 PM   #6
Well, I'd think you're about at the end of the 5.0 window. I Bootsy(?) said, going over 500hp is asking for it. I can't think of hearing about any sprayed 347.
Um. . .ask CHP?
Old June 29th, 2007, 10:44 PM   #7
89LX347's Avatar
hmm well the bottle is for sure going on it but i just wanna know how much
Old June 29th, 2007, 11:05 PM   #8
put the 100 shot on there and get the bitch tuned...Better hope it's not running lean...Personally, i would get a better block before i put nitrous on a 450 HP all motor production block...Get a nice Dart or ManOWar and NEVER buy another block. Some say the CHP blocks are stronger but i dont think so.
[SIGPIC][/SIGPIC]
[B][U]MM Sapper Squad[/U][/B]
Old June 30th, 2007, 12:40 AM   #9
Stangzilla's Avatar
Stangzilla is on a distinguished road
He said he has a 347 kit not a crate motor like I have from CHP. They use regular blocks for their 347 Street Fighter crate motor.. A 200 shot will really be pushing the block to the limit. I would not go over 125hp maybe 150hp at the most but you are takin a chance with the 150 shot.. Another thing with the nitrous you are really maxing out those 30lb injectors.. I hope you also have an inline booster pump..
Today, I found out that when I masturbate at night while watching internet porn I cast a huge shadow on the curtain and the entire street is able to see it.
Old June 30th, 2007, 01:52 AM   #10
89LX347's Avatar
i have the wet kit you still recomend the inline booster pump dont you?
Old June 30th, 2007, 01:53 AM   #11
89LX347's Avatar
i have the short block from them not just the rotating assembly
Old June 30th, 2007, 01:53 AM   #12
JBIGBOOTSY's Avatar
1990 LX hatch
do you have a factory fuel system?
Old June 30th, 2007, 01:58 AM   #13
JBIGBOOTSY's Avatar
1990 LX hatch
also, main studs and girdles cant stop a block from splitting, they just keep your caps from walking
Old June 30th, 2007, 02:34 AM   #14
Stangzilla's Avatar
Yes I do still reccommend it. What compression are you running?
Old June 30th, 2007, 02:35 AM   #15
ryans88gt's Avatar
Maxing out the injectors on a wet kit???
No such thing, try again...
I say spray two stages at it 125 out of the hole with another 200 coming on before the 330 ft mark. If you blow it up, then you know you really needed a 351w. If it holds together, it'll be one hell of a ride.
Old June 30th, 2007, 02:38 AM   #16
Stangzilla's Avatar
oops I missed that he said he had a wet kit. He still should get the booster pump and not listen to what you said about how much he should spray..
Old June 30th, 2007, 01:02 PM   #17
fogged306's Avatar
89 GT
You also might want to check ring endgap... Good rule of thumb is about .005-.006 per inch of bore on a nitrous motor.
Old June 30th, 2007, 01:09 PM   #18
JBIGBOOTSY's Avatar
1990 LX hatch
I say spray two stages at it 125 out of the hole with another 200 coming on before the 330 ft mark. If you blow it up, then you know you really needed a 351w. If it holds together, it'll be one hell of a ride.[/quote]
Yea spray what this guy says, 775hp on a stock block... thats the ticket.
Old June 30th, 2007, 02:28 PM   #19
89LX347's Avatar
im running about 10.4:1 compression and i have a 110lph fuel pump im pretty sure im gonna hop up to a 190 walbro
Old June 30th, 2007, 02:58 PM   #20
JBIGBOOTSY's Avatar
1990 LX hatch
just stick the main line from the bottle in your intake tube and turn the bottle on, then at the 330' do the same with another bottle. you should be good then.
Threads Similar to: Nitrous question
nitrous question BWAL 5.0 Mustangs 26 November 2nd, 2007 06:49 AM
nitrous jet question flattusmaximus78 V6 Mustangs 13 May 17th, 2007 11:12 PM
Another nitrous question ByPopularDemand V6 Mustangs 24 April 13th, 2007 02:29 AM
Nitrous Question 351stng 5.0 Mustangs 10 April 12th, 2007 12:21 PM
Another Nitrous Question keiken 96-98 7 March 2nd, 2007 10:05 AM
