smog pump delete
Old June 30th, 2007, 12:31 AM   #1
bigwhiskey is on a distinguished road
smog pump delete
i am getting rid of my smog pump but how can i plug the the holes in the cylinder head.
also what brand of spark plug runs the best in a stock 5.0
Old June 30th, 2007, 12:10 PM   #2
tording92lxnotch is on a distinguished road
If you have the heads off and have access to the back put some NPT plugs in to fill those holes where the smog pipe went. If you dont have access to the back then cut the tube and crimp it off to plug it. For plugs I would just run some standard NGK or Autolite plugs. Something without platinum.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old June 30th, 2007, 12:31 PM   #3
BCR93stang is on a distinguished road
Send a message via AIM to BCR93stang
Ya i just cut it with bolt cutters and pinched it shut. Works great! I also caped the vacuum lines.
Old June 30th, 2007, 05:29 PM   #4
sloppyjosey's Avatar
sloppyjosey is on a distinguished road
or cut the pipe and flip over the flanges. on the pollution pump u can take it apart and remove the vanes, then its just a free spining bearing.(if your on a budget)
"supernatural aspiration"
Old July 1st, 2007, 12:02 AM   #5
thanks
Threads Similar to: smog pump delete
Smog Pump Delete? 5-0stank 5.0 Mustangs 20 July 14th, 2008 05:24 PM
SMog pump delete kit javier351lx 5.0 Mustangs 9 August 20th, 2007 03:24 PM
How To Delete Smog Pump On 95 GT the95..5-0 5.0 Mustangs 2 September 13th, 2006 01:43 AM
Smog Pump Delete mdvaldosta 5.0 Mustangs 2 September 11th, 2006 12:13 PM
Smog Pump Delete? 00SoSlow V6 Mustangs 18 August 16th, 2006 01:04 AM
