Racing
2 questions.
1) When racing, where would you guys shift? As close to red lining as possible? 2) Any tips on not sitting in the same spot squealing your tires for 5 mins before you actualy get to move? |
haha 2 questions
1)what are ya driving...mods and car 2)im guessing manual tranny? my suggestion slicks for the second question
Yup its a manual, and i drive a 94 gt. Only mods are headers, straight pipe, and flowmaster.
just take the thing till it redlines and like i said slicks are your best choice or for your wheels do some good drag radials from micky thompson or nitto
For future reference when you get some more mods or change your setup. The way to figure out your shift point is simple if you have a few numbers. You will need your gear ratios, and your torque curve numbers. You've got a 94, so you have 3.35, 1.99,1.33,1.00,.675. Forget the .675 because you won't use it at the track. Since I am from Florida, I will make my example easy. I will use 3.0 for 1st and 2.0 for second. To find your rpm drop from one gear to the next divide the lower gear ratio by the higher. 3/2=.66 or 1/3. Say your torque is 240 at 6000 rpm and you know you will lose 1/3 of your rpm or 2000 rpm. If you know your torque at 4000 rpm is close to the same it is a good shift point. If your torque at 4000 is 200 then it is too soon to shift. If your torque at 4000 is 290 you shifted late. I'm not an expert at making up numbers and explaining them, so you can just go here and plug in your info if you really want to know. But the trick is to shift at an rpm that will give you the same torque in the next gear at that gears rpm.
http://www.bgsoflex.com/shifter.html
48.47@ 12.58
Thanks, I don't know why it does that, nor how to do what you did. I'll learn though.
Threads Similar to: Racing
| DSS Racing | Drgnracin72 | Vendors | 41 | October 28th, 2007 08:29 AM |
| I Need Help Racing | Dupes24 | Racer's Corner | 12 | October 22nd, 2007 06:51 PM |
| Racing a new BMW M5 | 06saleen3v | 2005 - 2010 | 22 | October 20th, 2007 02:10 PM |
| Ford Racing | thewayshemoves | 99-04 | 22 | December 29th, 2006 07:36 AM |
| racing in the 305 | black04GT | Multimedia | 5 | July 3rd, 2006 01:04 AM |
