wierd clunking noise from right rear
hey guys i just joined the site and i need some help. i have a 93 mustang gt. i replaced the upper and lower control arms with the bbk upper and lowers in the summer and just recently i got a clunking noise from the right rear. it happens when i reverse up a slight hill and when i accelerate a little. i can also feel a slight shift from the right rear when the noise occurs. any ideas on what it is??? if possible, if you guys have pics thats even better ....thanks!! ... mike
Welcome to the site Mike. Check everything new or not. Check the shock bushings. Quad shocks?? If so check the quad shock bushings. Check for loose hardware, missing hardware, or even torn torque boxes. Good luck.
if its the torque boxes are torn...are they hard to repair ??
#4 | |
1990 LX hatch
#5 | |
1990 LX hatch
Re: wierd clunking noise from right rear
stockm bolts
did you get the bolts for the the lower comtrol arms from the ford dealer because when i replaced my rearend in my car i put some bolts from the hardware store in them and they ended up being a little bit to small so now when i let the clutch out it rocks the rearend forwars and makes a weird clunk i am not saying that is what it is but i would check that if you did not get the bolts from ford
to be honest im not sure id have to ask my older bro because he is the one who installed them
check our trans mounts
usually when a torque box goes its the drivers side rear. for some strange reason this seemed to be true with almost all of the ones i've repaired. it sounds like you' ve got a bad bushing somewhere or lose hardware. if you're plannin on driven hard then you should get the local weld guy to weld up the torque boxes. if you are modded they WILL fail !!!!!!!!
Threads Similar to: wierd clunking noise from right rear
| wierd from noise | noppe180 | 96-98 | 5 | October 28th, 2007 02:26 AM |
| Wierd Noise..please help | tmab11 | V6 Mustangs | 1 | October 14th, 2007 06:48 PM |
| wierd grinding noise | G.T. Rags | 96-98 | 45 | September 14th, 2007 11:39 PM |
| Wierd noise...help plz if you can | Danny01gt | 99-04 | 15 | January 13th, 2007 12:19 AM |
| wierd noise suggestions? | 02NEBstang | 99-04 | 2 | December 22nd, 2006 08:29 PM |
