Starts and Dies
Old July 3rd, 2007, 11:28 PM   #1
RDR61 is on a distinguished road
Starts and Dies
I have a 1990 5.0 5spd mustang that turns over and starts then dies immediately, every time I turn it over, any help would be appreciated !
Old July 3rd, 2007, 11:34 PM   #2
88dragstang is on a distinguished road
Could be several things. Make sure your mass air sensor isnt dirty. Whatever you do, dont touch it! Spray it with brake cleaner and let it air dry. Could be a bad ignition switch under the column which is pretty inexpensive and easy to change. Could be a dirty fuel filter. Does it have the check engine light on?
Old July 3rd, 2007, 11:41 PM   #3
mass air is clean, has new ignition switch, fuel filter is fairly new as well, problem just started this afternoon, car ran fine this morning.
Old July 3rd, 2007, 11:56 PM   #4
neverfastenough1's Avatar
Here's a list of causes (not saying its a complete list, but its the book list). Ignition system-Electrical connectors, secondary wires, coil,ignition module,rotor alignment, cap, stator, fouled plugs, ignition switch, ballast resistor; EGR valve; Fuel delivery-filter, pump, contamination, fuel lines, sender filter, idle air flow, inertia switch, anti theft, injectors, fuel pressure regulator; Exhaust restricted; EEC-processor and calibration assy, quick test; basic engine-camshaft timing, valve train. Man there really is a lot it could be. I'd start with the quick test, ie. check for codes.
Old July 4th, 2007, 10:11 PM   #5
LMAO!!! If you are gonna check all of that, dont forget the muffler bearings and the blinker fluid. Oh, and the partridge in a peartree. Hehehe
Threads Similar to: Starts and Dies
88 5.0 sometimes starts but won't stay running cylance 5.0 Mustangs 8 August 28th, 2011 05:59 PM
hard starts steve505gt 99-04 13 October 23rd, 2007 07:56 PM
OSU starts it off right! 03 R Code The Clubhouse 23 September 2nd, 2007 09:38 PM
starts then shuts off sean97gt 96-98 2 January 18th, 2007 12:45 PM
starts then shuts off sean97gt 96-98 3 January 18th, 2007 01:00 AM
