How much boost can I handle?
Old July 5th, 2007, 03:23 AM   #1
Cor9er is on a distinguished road
Hi I have a 95 GTS with Edelbrock Performer heads and Powerdyne supercharger and more, I am currently putting out about 412 HP, just wanted to know how much boost a stock 302 block can handle. I am currently running 6 pounds of boost. I want to upgrade to a 11 pound pulley. Thanks in advance.
Old July 5th, 2007, 04:58 AM   #2
tording92lxnotch is on a distinguished road
Well the boost is not the actual problem. The problem is the power your going to create from the added boost. The stock block on a 5.0 will split down the middle right around 500 hp. I have seen some last for a short while making like 550 but overall the limit is 500. I would probably not go over 470 or so if you want it to last very long at all. I would say with 11 lbs you will probably be right at 500 hp so you might want to switch to a 9 psi pulley first and see what kind of power you make on a dyno and then switch to the 11 if your below 500.
92 notch--Shorty headers--Pro 5.0--3G alt--U/D pullies--A/C delete--190 LPH Walbro FP--Compucar N2O kit--FMS alum D/S--Taurus fan--Weld Draglites--Mallory 685 ign Box--dccontrol fan controller
13.0 - 108 mph - 1.9 60' - 90 shot N2O and 175k on the clock
Old July 5th, 2007, 07:05 PM   #3
Awesome thanks for your input.
Threads Similar to: How much boost can I handle?
Need to HANDLE HP trueballerisme V6 Mustangs 64 June 18th, 2007 10:51 PM
how much can the 3.8 actually handle? 94v6blkndred General Tech 2 May 23rd, 2007 07:44 PM
Will the t-5 handle it? 93'_GT 5.0 Mustangs 17 May 11th, 2007 11:12 PM
can it handle it? 9stang1 5.0 Mustangs 10 December 15th, 2006 04:52 PM
Turbo Boost vs Super Boost droppedbass87 General Tech 12 October 16th, 2006 09:56 AM
