1989 GT Hatch
what a waste of money
'89 5.0 gt t5 still slow as hell.
trick flow street upper and lower 65mm tb and spacer bbk cai new #19 injectors bbk 255lph fuel pump bbk adjustable regulator with gauge 180* thermostat mac shorties offroad h pipe flowmaster 40's timing advance 3:73 gears |
![]() Did you put gas in it?
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
89 GT
You should notice a considerable difference with all that. Maybe a tune will wake it up?
1987 ford mustang gt
well see when shes done
What do you mean slow
Do you drive supercars all day long? That's not a bad set-up... Maybe you just need a tune?
1989 GT Hatch
barely can tell i did anything to it.
1989 GT Hatch
how fancy are tunes on these old 5.0's, is it more than uping my fuel pressure and advancing the dizzy a bit for 91 octane?
So I'm looking over your mod list, and I noticed you have 19# injectors.. I'm no expert on 5.0s, but that sounds a little weak for your mods.. maybe thats why your not feeling anything?
89 GT
Nah, those 19# injectors are fine for what he's got.. I would get some type of piggyback computer or at the least have a chip burned for the car. If you don't plan on doing more mods to the car then the chip will save you money. If you are going to do other things to the car, a computer will save you in the long run because you wont have to reflash or buy a new chip everytime you change something.... even with out a chip or computer you should feel at least a little difference. I think something isn't right... timing, bad sensor somewhere causing the computer to run in limp mode, vac leak.
did the car seem abnormally slow before the mods? maybe there is something wrong with the car. |
#10 | |
edit: what about the puny 55mm MAF meter? you don't still have the stocker on there do you? how are the breathing mods going to help if you're sucking through a straw??? |
#11 | |
maybe you should Check Your Codes? |
#12 | |
1989 GT Hatch
#13 | ||
these formulas are for flywheel HP:
#14 | ||
1989 GT Hatch
i know i still have to play with my timing, today was just the first quick test drive after getting it running. yeah still stock maf. i researched these mods before buying them and nobody said go bigger with the maf. (hey i cleaned it...haha) |
#15 | |||
1989 GT Hatch
#16 | ||||
#17 | ||
1989 GT Hatch
89 GT
definitely get a bigger MAF. you are doing exactly what TENGRAM says and bottlenecking the entire upgraded air flow you just put on there. Just make sure it is calibrated for 19# injectors... or you can do a cobra 70mm.
oops.... too late |
Dude, I would gain hp on my car (2.3L) by upgrading to 24lb injectors. I just assumed 19 would be a bit small for you.
Bro its a mustang, of course its gonna be slow. The only way to make it "fast" is go F/I, or get a Cobra and drop 2 G's into it.
Threads Similar to: what a waste of money
| what a waste of tax dollars.. lol | BWAL | Pictures | 9 | October 29th, 2007 04:08 PM |
| mm.com help quick i dont wanna waste money | blown96stang | V6 Mustangs | 17 | September 27th, 2007 04:33 PM |
| WRX waste | TDog | 2005 - 2010 | 65 | August 15th, 2007 06:06 PM |
| what is a waste of money? | chase | 5.0 Mustangs | 1 | April 8th, 2007 09:33 PM |
| Money | ScreaminYellow05 | The Clubhouse | 8 | February 1st, 2007 03:03 AM |
