Mechanical pump, or existing in-tank pump?
Old July 9th, 2007, 12:37 AM   #1
shnipplelicken is on a distinguished road
Send a message via AIM to shnipplelicken
ok, so heres whats up. I just did my first engine swap on my '90 stang. The V8 is from a '79 stang. My problem, or at least one of my problems, is that my car used to be EFI and the engine is carburated. My question is: can the mechanical pump still suck gas through the pump in the tank, even if the in-tank pump is disabled? Can I just use the in-tank pump to send fuel to the carb and just remove or bypass the mechanical pump? How should I go about doing this?
Old July 9th, 2007, 06:55 AM   #2
neverfastenough1's Avatar
Definitely go with electric if possible. Reason being, mechanical pumps use hp to pump. You can use the in tank pump you have with a pressure regulator.
Old July 9th, 2007, 09:28 AM   #3
JBIGBOOTSY's Avatar
1990 LX hatch
mallory makes a specific fuel pressure reg. for using the in-tank pump with a carb. You will not be able to pull fuel through the intank pump if you use the mech. pump.
Old July 9th, 2007, 09:59 AM   #4
Yeah, you would have to pull the pump off and run a line from the pickup tube to the bottom of the tank. With a screen.
Old July 11th, 2007, 09:04 PM   #5
ok, I guess its the electric pump FTW, but whats the exact regulator that I should use? Everything I've seen is between 30 and 60 psi. I was told that I should regulate the flow to about 6 or 7 psi to the carb. True?
Old July 11th, 2007, 09:34 PM   #6
JBIGBOOTSY's Avatar
1990 LX hatch
mallory fuel pressure reg. part #4309
Old July 11th, 2007, 10:21 PM   #7
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 7 reviews
Yes electric pump FTW...... you need a 0-15psi regulator with a return bypass. I just got done converting my car over to carb and am still using my EFI BG Mighty Sumo pump. As long as the return line is large enough it will work great.
TT Build in progress.......
Old July 12th, 2007, 12:47 AM   #8
ryans88gt's Avatar
Yeah +1 on the return line.
I have a 140 gph out of tank electric pump designed for carbs with a 3/8" feed line. Originally I tried using the stock return line and the lowest I could get the fuel pressure down to was like 12 PSI. So I switched the routing around so that the factory feed line is my return line and this brought the pressure down to about 7-8 PSI. However, even with the 5/16" feed line as my return I can't turn the pressure down past 7-8 PSI...
With the factory EFI pump I could regulate between 3 PSI and 30 PSI using the factory feed and return line.
Threads Similar to: Mechanical pump, or existing in-tank pump?
2007 Pump Gas Drags 32 of the fastest pump gas cars Mellon Videos 7 June 14th, 2008 01:08 PM
How much HP mechanical fuel pump can handle?? hitorx 5.0 Mustangs 1 June 12th, 2007 12:50 AM
svt focus pump vs. ford GT pump undomesticfire 99-04 3 May 15th, 2007 08:10 PM
A1000 Pump With 255lph In-Tank Pump ? 92lx5oh 5.0 Mustangs 11 March 18th, 2007 09:51 PM
302 mechanical fuel pump 03stanger 5.0 Mustangs 2 July 18th, 2006 12:24 PM
