throttle body size question
I've got a stock 89 GT. I just put some shorty headers on it and now I want to put a bigger throttle body. I was wondering how big I can go and still keep it naturally aspirated at the moment. I don't want to change the injectors just yet. I plan to maybe one day get a supercharger and fuel injectors and a T/F intake. what are the problems on going too big? If anyone has a brand recomendation, let me know. Also, will I be able to use the stock intake tubing or should I get a cold air kit with the throttle body.
thanks Mike
- '90 Mustang LX-Sold "Debbie" - '89 Mustang GT- Deceased "Lucy" - '91 Mustang GT-70,000 mi "The Unicorn" |
You'll probably want no bigger than a 65mm until you do some hefty mods. It also helps to get a better MAF housing, otherwise your precious 65mm TB is being fed by a 55mm MAF housing. You can get CAI, but don't be silly about it. It's a pipe that goes from the fender to the TB - get something cheap on ebay. Just because it says BBK doesn't mean it's better than. . .some other metal pipe. ..
Also, look into getting a 65mm EGR plate if you bump up the TB. |
What other mods do you have? A throttle body upgrade is pretty much useless unless you have heads, cam, intake, MAF upgrades.
whats MAF?
Mass Air Flow sensor. It is before your throttle body.
I just have exhaust headers with no cats and some custom h pipes. 3.73 gears in the rear but not a whole lot done. I guess if i don't have a lot of engine work done like heads, cam, intake the upgrade is kinda useless huh? maybe Ill put it off till I get a cam and intake or something.
#7 | |
#8 | ||
#9 | |||
1990 LX hatch
#10 | |
1990 LX hatch
I don't know what the material in the felpro 1262 intake gasket is, but it is a bitch to clean, I've found that pb blaster is good for that. Yea in the past year I have changed my oil sooo much because of all the carp that has gotten into my engine from changing stuff. I have no AC so I'm good there, thats gotta suck though, I've never thought about that. and to top it off I found an oil leak at both the front and back of the intake to vally gasket, so off again with the intake. I did find a coolant drain plug just under the #1 cyl. that helps alot. it's a 1/4" allen head. I never knew it was there.
#12 | |
1990 LX hatch
on the block about half-way down about 2" in front of the passenger side motor mount.
#14 | |
Threads Similar to: throttle body size question
| Throttle Body Question | 95blackbeauty | 94-95 | 2 | September 17th, 2007 11:55 PM |
| What size throttle body? | Euroeater95 | 94-95 | 1 | July 6th, 2007 05:29 PM |
| Biggest size Throttle Body for 4.6 sohc? | silver_96 | 96-98 | 2 | January 13th, 2007 06:14 PM |
| throttle body question | RyanGT | 99-04 | 32 | January 8th, 2007 11:05 PM |
| Question About Throttle Body | BiGD12590 | 99-04 | 14 | July 30th, 2006 10:47 PM |
